ITHO plugin
Posted: 03 Nov 2022, 20:02
Maybe i could ask a question?
The last week i've been busy to make the remote control for the ITHO fan working.
To be honnest, that was not a big problem with all the fine explanations i found.
But still i am struggling with an issue:
I want to send a command from ESP1 (with moist sensor) to ESP 2 (with CC1101 and two servo for controlling air flow) by EASYP2P networking.
This is because i do not want to be dependant on wifi.
Activation of the servo's is no problem, but what is the command to set the ITHO fan low and high?
The only commands i can find are the MQTT and HTTP commands, but no "internal" command.
I assume there is a way to send a "sendto" event from ESP1 to ESP2, or a rule command in ESP2 triggered by a "sendto" command from ESP1?
Any help would be much appriciated.
