SDS011+ESPEasy: which setup is valid?
Posted: 12 Dec 2022, 19:00
For years have used the SDS011 Dust-sensor in the 'official' Luftdaten-configuration, in combination with BME280/DHT22.
However, some months ago the setup broke-down, and no revival if reflashing & restarting.
Now question: which part is at fault?
'No reflash possible' seems to hint that the NMCU has 'gone':
that leaves SDS011 and BME280/DHT22 as elements for check & recycling.
Using ESPEasy MEGA_2020310 in various of my ESP8266s, I see Dust - SDS011/018/198 in the menu for devices.
In the forum also found a message_with_description for setup.
Simple question:
is that message_with_description the latest & greatest for a Dust-setup with SDS011?
Heating-modification
Would like to insert a 'twist' in the setup described:
for controlled heating the programmable PWM-output from the ESP8266 might be used instead of a relais.
Have applied such PWM-signal as feed for humidity-measurement, but not yet with heating:
any forum-member with experience on such heating-setup?
Simple question:
