WiFiAPMode doesn't work again
Posted: 16 Mar 2023, 12:01
I used yesterdays build and realized that "WiFiAPMode" doesn’t work. I am not entirely sure, but i think it was already working a while ago...
185317 : Info : HTTP: WifiAPMode
185425 : Info : WIFI : Set WiFi to AP+STA
185535 : Info : WIFI : AP Mode ssid will be chickendoor with address 192.168.4.1
185561 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 2 m 10 s
185562 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: Conn. IP Init
185663 : Info : WiFi : WifiDisconnect()
185764 : Info : WIFI : Disconnected! Reason: '(1) Unspecified'
185865 : Info : Reset WiFi.
185867 : Info : WiFi : Start network scan all channels
188055 : Info : WiFi : Best AP candidate: *********************** Ch:9 (-41dBm) WPA2/PSK
188056 : Info : WiFi : Scan finished, found: 14
188059 : Info : WiFi : Best AP candidate: *********************** Ch:9 (-52dBm) WPA2/PSK
188060 : Info : WiFi : Added known candidate, try to connect
188061 : Info : WiFi : WifiDisconnect()
188163 : Info : WIFI : Disconnected! Reason: '(1) Unspecified'
188164 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
188265 : Info : Reset WiFi.
188268 : Info : WiFi : Start network scan all channels
190455 : Info : WiFi : Scan finished, found: 12
190458 : Info : WiFi : Best AP candidate: *********************** Ch:9 (-51dBm) WPA2/PSK
190460 : Info : WiFi : Added known candidate, try to connect
190561 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
190562 : Info : WIFI : Set WiFi to OFF
190879 : Info : WIFI : Set WiFi to STA
190985 : Info : WIFI : Connecting *********************** Ch:9 (0dBm) - attempt #2
191001 : Info : EVENT: WiFi#APmodeEnabled
192027 : Info : EVENT: WiFi#Disconnected
192160 : Info : WIFI : DHCP IP: 192.168.1.107 (chickendoor) GW: 192.168.1.1 SN: 255.255.255.0 DNS: 192.168.1.1 / (IP unset) duration: 141 ms
192166 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: IP
192168 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 14344 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: IP
192176 : Info : WIFI : Connected! AP: *********************** Ch: 9 Duration: 1017 ms
192183 : Info : EVENT: Clock#Time=Thu,10:53
192291 : Info : EVENT: WiFi#Disconnected
192405 : Info : EVENT: WiFi#Disconnected
192512 : Info : EVENT: WiFi#APmodeDisabled
192625 : Info : EVENT: WiFi#Connected
192737 : Info : EVENT: WiFi#ChangedAccesspoint
192846 : Info : EVENT: WiFi#ChangedWiFichannel
