TFT st7789 send http
Posted: 28 Apr 2023, 18:50
by marktn
Re: TFT st7789 send http
Posted: 28 Apr 2023, 19:17
by Ath
Close but no cigar
For the 'regular' commands, provided via the AdafruitGFX_Helper extension, the commands are
not postfixed with cmd, so the command to display text on the display would be st7789,txt,text or st7789,txt,"text containing spaces, and/or commas".
You might consider using st7789,txz,x,y,"test to display at a specific position", where you have fine control over the exact position the text is displayed.
Full command documentation for the ST77xx plugin is
found here (you can scroll up for the complete plugin documentation)
Posted: 28 Apr 2023, 20:44
by marktn
Ath wrote: ↑28 Apr 2023, 19:17
Close but no cigar
Thanks!! That worked.
192.168.1.82/control?cmd=st7789,txl,3,"TEST TEXT"
Is it also possible to make the background of a txl in the color red? I see color settings, but how to use it in a line.
Posted: 28 Apr 2023, 21:08
by Ath
marktn wrote: ↑28 Apr 2023, 20:44
Have a look at the txtfull command that has a lot of parameters including foreground and background colors, or the txc command that allows to change the standard colors (foreground and background).
Posted: 28 Apr 2023, 21:25
by marktn
Ath wrote: ↑28 Apr 2023, 21:08
I have seen that, but i can get it in a line, txl
It looks like it is only possible with pixel position, not in a line height.
Posted: 28 Apr 2023, 22:04
by Ath
marktn wrote: ↑28 Apr 2023, 21:25
That depends on the 'Text Coordinates in col/row' setting in the Device Configuration page, txl always uses the row/col setting, instead of pixels, by design.
txl was added on request for P141 Nokia 5110 display, so send the (few only) lines that can be displayed on that display.
You can send a txc command, setting the desired color, then the txl command to display the text, and restore the colors using a new txc command. That can not be combined in a single command.
Posted: 29 Apr 2023, 11:36
by marktn
Thanks for your support! It is working.
I have another question for the TFT st7789, i will make a new topic for that.
viewtopic.php?t=9631
Posted: 13 Sep 2023, 19:53
by marktn
192.168.1.xx/control?cmd=st7789,txtfull,1,5,3,<foreColor=current>,blue, <textPrintMode=current>,<maxTextWidthPixels=0>," Tekst "
With this http rule i have backgroud color, and text. Works fine.
Is there also a rule to clear this rule with text and colour? Not the complete screen.
Mark
Posted: 13 Sep 2023, 20:38
by Ath
marktn wrote: ↑13 Sep 2023, 19:53
Instead of the text you could write a series of spaces...?
Posted: 13 Sep 2023, 22:01
by marktn
Ath wrote: ↑13 Sep 2023, 20:38
That is possible. But then will not remove the color. And there is no color that is the same as the screen is.
Posted: 13 Sep 2023, 22:12
by Ath
marktn wrote: ↑13 Sep 2023, 22:01
Normally, using the same background color as the foreground color, it should result in 'transparent', though I haven't tested that using spaces. The default background color is black (you can use color names, as documented)
Posted: 13 Sep 2023, 22:41
by marktn
Ath wrote: ↑13 Sep 2023, 22:12
I did test that. But black is white. It looks like that the colors do not match the colors in the http rule.
The background is black.
