Rule on no data with timer
Posted: 04 Jun 2023, 22:55
I have one ESP that sometimes hang, and need some love then. But an other ESP is running with an 7dgt on it showing the temperature. Now it shows continue the old value untill received new data. Thought I had an solution with rules but I can't get it to work. On startup showing boot till first data received works fine. Here my code:
So in my opinion it's when receiving data on the MQTT topic it starts the timer for 90 seconds, every time data is received the timer is set to again 90 seconds. If the timer hits the end before date received it shows lost on the 7dgt and sets the timer to 0.
The "on MQTT#Buiten do" and "7dtext,lost" are the only lines i know for sure they work, because they work in a other rule.
Can someone help me please?
on MQTT#Buiten do
timerSet,1,90
On Rules#Timer=1 do
7dtext,lost
timerSet,1,0
