mqtt disconnect every 30 sec.
i have an wemos mini d1 with espeasy and the counter. The wemos communicate ovewr mqtt with my iobroker. for 30 sec everything works fine. then mqtt lost connection and an other 30 sec it reconnect.
See attachfile
any ideas?
See attachfile
any ideas?
- Snap4.jpg (173.93 KiB) Viewed 1236 times
Re: mqtt disconnect every 30 sec.
Might not be for the same reason as in this GitHub issue, but at least there were some possible causes discussed which you could also look into.
For example:
- Poor WiFi connection
- ESP receiving too many messages on subscribed topics
- Too low timeout in the controller settings in ESPEasy
- Increase "keep alive" setting in the MQTT broker
- ECO mode enabled on ESPEasy? If so, try with disabling it
For example:
hi,
thanks for the quick response.
Answers:
- Poor WiFi connection connection
802.11g (RSSI -64 dBm)
where can i find it?
client timeout 200ms tryed also 1000 . no efect
where can i do this?
you mean sleepmode? ist off or Where can i find it?
Answers:
OK, so WiFi connection is good at -64 dBm
Number of messages received....
Maybe the broker does keep some logs?
Otherwise you could use some desktop tools like MQTT Explorer (Windows store) to subscribe to the same topics as what your ESPEasy node does.
Then you can see what messages (and how many) must have been sent to the ESPEasy node.
The MQTT broker does have this keep alive setting, so it must be in the MQTT broker configuration somewhere.
ECO mode in ESPEasy is not enabled by default. You can find it on the Tools->Advanced page.
hi,
so mqtt exlorer has not much communication. see attach mqtt_ex
IObroker mqtt Settings see attach mqtt_iobroker_set. i cant find the alive
eco mode is disable
eco mode is disable
- mqtt_iobroker_set.jpg (139.79 KiB) Viewed 1215 times
- mqtt_ex.jpg (87.02 KiB) Viewed 1215 times
Does the log of your MQTT broker share any info on who initiated the MQTT disconnect?
Either the MQTT broker or the MQTT client?
Can you also try to uncheck the "ack=true" to see if this also means the client needs to send an acknowledgement?
hi,
ack true disable and the iobroker lo see attch
same result.
same result.
- iobroker_log.jpg (62.55 KiB) Viewed 1209 times
hi,
i read something about to add a loop in esp. but i dont know where to add.
Where did you read this? It doesn't ring a bell here and I also can't think of a way how that may help these issues.
I don't really understand what's being posted here...
It looks more like the log of the MQTT broker indicating the broker might have crashed and is restarting?
hi,
i change the intervall time from 10 to 40. now the mqtt is 60 sec online and only 5 sec offline. before changing ist was 30 sec online 30 sec offline.
You might consider upgrading your IOBroker installation to the latest release (4.3.4), as you seem to be on a somewhat older version (4.1.1) (all according to some googling...)
mqtt 4.1.1 is the last stable version.
hi, i have no ideas left
