Download the modbus protocol here :
https://www.kdocs.cn/l/cnQKPZECE6eY
Wenzhou Taiye Electric Co., LTD TAC2100 series Modbus Protocol v1.0
Measuring class parameter [Floating point format data]
Input Register Parameter
[ Function code : 04H ]
Register Address
[Hex]
Description Length
(bytes)
Data
Format Units High
Byte
Low
Byte
Voltage. 4 Float V 00 00
Current. 4 Float A 00 06
Active power. 4 Float W 00 0C
Reactive power. 4 Float var 00 12
Apparent power. 4 Float VA 00 18
Power factor (1). 4 Float None 00 1E
Phase angle. 4 Float Degrees 00 24
Frequency of supply voltages. 4 Float Hz 00 30
Nature of load (Resistive=1, inductive=2, capacitive
=3, Non Load=4) 4 Float None 00 4E
Active power demand (2). 4 Float W 00 8C
Reactive power demand (2). 4 Float var 00 8E
Apparent power demand. 4 Float VA 00 90
Current demand. 4 Float A 00 92
Import active power demand 4 Float W 00 9A
Export active power demand 4 Float W 00 9C
Maximum active power demand (2). 4 Float W 00 A2
Maximum reactive power demand (2). 4 Float var 00 A4
Maximum apparent power demand. 4 Float VA 00 A6
Maximum current demand. 4 Float A 00 A8
Maximum import active power demand 4 Float W 00 B0
Maximum export active power demand 4 Float W 00 B2
Total import active energy. 4 Float kWh 05 00
Total export active energy. 4 Float kWh 05 02
Total active Energy. 4 Float kWh 05 04
Total import reactive energy. 4 Float kvarh 05 08
Total export reactive energy. 4 Float kvarh 05 0A
Total reactive Energy. 4 Float kvarh 05 0C
Notes:
1. The power factor has its sign adjusted to indicate the direction of the current. Positive refers to
forward current, negative refers to reverse current.
2. The power sum demand calculation is for import – export.
Measuring class parameter [Integer format data]
Holding Register Parameter
[ Read : Function code : 03H ]
Register Address
[Hex]
Description Length
(bytes)
Data
Format Units High
Byte
Low
Byte
Voltage. 4 ULONG 0.01V 00 00
Current. 4 ULONG 0.001A 00 06
Active power. 4 LONG 0.001kW 00 0C
Reactive power. 4 LONG 0.001kvar 00 12
Apparent power. 4 ULONG 0.001kVA 00 18
Power factor (1). 2 INT 0.001 00 1E
Phase angle. 2 INT 0.01° 00 21
Frequency of supply voltages. 2 UINT 0.01Hz 00 2A
=3, Non Load=4) 2 UINT None 00 46
Active power demand (2). 4 LONG 0.001kW 00 66
Reactive power demand (2). 4 LONG 0.001kvar 00 68
Apparent power demand. 4 ULONG 0.001kVA 00 6A
Current demand. 4 ULONG 0.001A 00 6C
Import active power demand 4 ULONG 0.001kW 00 74
Export active power demand 4 ULONG 0.001kW 00 76
Maximum active power demand (2). 4 LONG 0.001kW 00 7C
Maximum reactive power demand (2). 4 LONG 0.001kvar 00 7E
Maximum apparent power demand. 4 ULONG 0.001kVA 00 80
Maximum current demand. 4 ULONG 0.001A 00 82
Maximum import active power demand 4 ULONG 0.001kW 00 8A
Maximum export active power demand 4 ULONG 0.001kW 00 8C
Total import active energy. 4 ULONG 0.01kWh 04 00
Total export active energy. 4 ULONG 0.01kWh 04 02
Total active Energy. 4 ULONG 0.01kWh 04 04
Total import reactive energy. 4 ULONG 0.01kvarh 04 08
Total export reactive energy. 4 ULONG 0.01kvarh 04 0A
Total reactive Energy. 4 ULONG 0.01kvarh 04 0C
Notes:
Set class parameters
[ Read : Function code : 03H ; Write : Function code : 10H ]
Register
Address
[Hex]
Parameter Description Length
(bytes)
Data
Format
High
Byte
Low
Byte Mode
Key Parameter
Programming
Authorization
(KPPA)
Read: to get the status of the KPPA
0 = not authorized;1 = authorized
Write the correct password to get KPPA,
enable to program key parameters.
2 UINT 50 00 R/W
Demand Period
Write demand period: 0~60 minutes,
Default 60.
Range: 0~60, 0 means function update
every second.
2 UINT 50 02 R/W
Slide time Default 1, min.
Range:1 ~ (Demand Period -1). 2 UINT 50 03 R/W
Modbus address
Write the modbus address
Range: 1 to 247 for MODBUS Protocol,
default 1.
2 UINT 50 05 R
Network Baud
Rate
Write the network port baud rate for
MODBUS Protocol, where:
0 = 1200 baud.
1 = 2400 baud.
2 = 4800 baud.
3 = 9600 baud, default.
4 = 19200 baud.
5 = 38400 baud.
2 UINT 50 06 R
Parity and stop bit
Write the network port parity/stop bits for
0 = One stop bit and no parity, default.
1 = One stop bit and even parity.
2 = One stop bit and odd parity.
3 = Two stop bits and no parity.
2 UINT 50 07 R
Password
Read: to get the password of the meter
Write: to program the new password of
the meter
Default : 0000
(KPPA is asked)
2 UINT 50 08 R/W
Pulse 1 Energy
Type
Write MODBUS Protocol
input parameter for pulse
output 1:
1: import active energy
2: total active energy
4: export active energy, default
5: import reactive energy
6: total reactive energy
2 UINT 50 09 R/W
8: export reactive energy
Pulse 1 constant
Write pulse constant index: n
= 0 to 3
0 : 1000 imp/kWh(kvarh), default
1 : 100 imp/kWh(kvarh)
2 : 10 imp/kWh(kvarh)
3 : 1 imp/kWh(kvarh)
4 : 10kwh/imp
5 : 100kwh/imp
6 : 1000kwh/imp
Note: When the pulse constant is equal
to 1000 imp/kWh(kvarh), the pulse width
time cannot be set to 200ms.
2 UINT 50 0A R/W
Pulse 1 Width
Write pulse on period in milliseconds:
60, 100 or 200, default 100.
Note: The pulse width time cannot be set
to 200ms when the pulse constant is
equal to 1000 imp/kWh(kvarh).
2 UINT 50 0B R/W
Automatic Scroll
Display Time
Automatic scroll display time, unit :
second
Range 0~60,default : 0
Note: 0 mean stop automatic scroll
display
2 UINT 50 18 R/W
Backlit time
Backlit time, unit : minute.
Default 60.
Range 0~120 or 255 , 0 means backlit
always on,255 means backlit always off.
2 UINT 50 19 R/W
Running time
( Data in units of
minutes)
Running time. Unit : minute.
Write 0 to reset the running time with
load. No response if write other value.
Note: The meter starts timing when
it's powered on
4 ULONG 50 3C R/W
Running time with
load
( Data in units of
minutes)
Running time with load. Unit : minute.
power greater than 0 detected
4 ULONG 50 3E R/W
Reset historical
data
0 = reset max. demand
(KPPA is asked) 2 UINT 56 00 W
Meter code The code of the meter 2 HEX 56 01 R
Serial number The serial number of the meter 4 ULONG 56 02 R
Software version
number
Software version number : XX.YY
Data definition : The first byte represents
XX, and the second byte represents YY
2 HEX 56 04 R
Hardware version
number
Hardware version number : XX.YY
Data definition : The first byte represents 2 HEX 56 05 R
version number of
displayed
version number of displayed : XX.YY
2 HEX 56 06 R
Example:
1, Read Input Registers
Example: Read “Phase 1 line to neutral volts”
Request: 01 04 00 00 00 02 71 CB
Where, 01 = Meter address
04 = Function code
00 = High byte of registers starting address
00 = Low byte of registers starting address
00 = High byte of registers number
02 = Low byte of registers number
71 = CRC Low
CB = CRC High
Response: 01 04 04 43 66 33 34 1B 38
04 = Function code
04= Byte count
43 = Data, (High Word, High Byte)
66 = Data, (High Word, Low Byte)
33 = Data, (Low Word, High Byte)
34 = Data, (Low Word, Low Byte)
1B = CRC Low
38 = CRC High
Note: 43 66 33 34(Hex) = 230.2 (Floating point)
Example: Read “Phase 1 line to neutral volts” (ULONG Format)
Request: 01 03 00 00 00 02 C4 B0
03 = Function code
C4 = CRC Low
B0 = CRC High
Response: 01 03 04 00 00 61 AA 53 DC
04 = Function code
04= Byte count
00 = Data, (High Word, High Byte)
00 = Data, (High Word, Low Byte)
61 = Data, (Low Word, High Byte)
AA = Data, (Low Word, Low Byte)
53 = CRC Low
DC = CRC High
Note: 00 00 61 AA(Hex) = 25002(ULONG) * 0.01V = 250.02V
2, Read Holding Registers
Example: Read “Slide time”
Request: 01 03 50 03 00 01 65 0A
03 = Function code
50 = High byte of registers starting address
03 = Low byte of registers starting address
01 = Low byte of registers number
65 = CRC Low
0A = CRC High
Response: 01 03 02 00 05 78 47
03 = Function code
04= Byte Count
00 = Data, (High Byte)
05 = Data, (Low Byte)
78 = CRC Low
47 = CRC High
Note: 00 05 (Hex) = 5 (UINT)
3, Write Holding Registers
Example: Write “Demand Period” = 30
Request: 01 10 50 02 00 01 02 00 1E 77 BF
10 = Function code
02 = Low byte of registers starting address
02 = Byte Count
1E = Data, (Low Byte)
77 = CRC Low
BF = CRC High
Note: 00 1E (Hex) = 30(UINT)
Response: 01 10 50 02 00 01 B1 09
10 = Function code
B1 = CRC Low
09 = CRC High
