!serial rules filter
Galan
#1 Post by Galan » 22 Sep 2023, 23:32
Hello guys,
With some perseverance=https://www.letscontrolit. ... php?t=9520, and help from Ath and td-er (again my thanks!!), I succeeded to make rflink and esp easy over mqtt works :)
now I'm goofing around with rules but bumping my head agents an action what I'd like
I want to give buttons in ESP easy their own name, so over MQTT only the name and status is sent. I thought it's easier to do the translation in ESP Easy than Home Assistant.
So !Serial#20;E2;TriState;ID=0a82a2;SWITCH=0;CMD=ON; must become dom/button/a, "on"
I've tried the lines below as test and only the first and second works. Does someone have a suggestion? I do not want to do the translation in node-red
on !Serial do
 Publish, %sysname%/switch,  %eventvalue% // The data is added after the # as the event-parameter name
 Publish, %sysname%/switch,  {substring:26:32:%eventvalue%}
Let, temp, {substring:26:32:%eventvalue%}
Publish, %sysname%/switch, [var#temp]
If {equals_ci:'{0a82a2}':{substring:26:32:[%eventvalue%]} }= 1
    Publish, %sysname%/switch, niet_waar
 Endif
If %eventvalue% ='{TriState;ID=0a82a2;SWITCH=0;CMD=ON;}'
 Publish, %sysname%/switch, niet_waar2
//!Serial#20;E2;TriState;ID=0a82a2;SWITCH=0;CMD=ON;
Many thanks for suggestions.
Greetings
Re: !serial rules filter
#2 Post by TD-er » 22 Sep 2023, 23:53
You can only compare against numerical values.
Not strings.
So
if %eventvalue1%=
like statements can only compare against numerical values.
Galan
#3 Post by Galan » 16 Oct 2023, 14:50
tnx for your reaction. I'll solve it then in HA. btw sorry for the late reaction.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
