Before I had the fancy webserver layout whereas 'out of the blue this seems to have changed as per screenshot.
Might be somewhere a setting? Or ....?
TIA
-Bart
webserver pops up as text only
- Schermafbeelding 2023-11-12 131642.jpg (143.7 KiB) Viewed 1832 times
Re: webserver pops up as text only
Yep, that's an issue which has been reported a few times in the past week.
It seems the CDN hosting the static files like the CSS is no longer serving the files.
We're looking into this.
BTW same shows up once I flash collection A from your website.
Yep, there's something seriously wrong with the CDN served content.
You could upload the CSS file to the ESP as a work-around.
The files are here:
https://github.com/letscontrolit/ESPEas ... ega/static
But I guess you will also miss the JavaScript files.
So I think I will add an option to allow the user to define the base URL for the CDN server and maybe setup a server myself to host the CDN files by default.
The files are here:
I hope you don't mind but CDN does not ring a bell for me.
Content Delivery Network.
In short, some server that will provide extra bandwidth and storage to host files needed by many users.
Typically some standard web libraries like JQuery or lots of stuff just anybody needs to browse the web, are hosted on CDN servers so they can be served with the lowest latency, highest uptime guarantee and with the best available bandwidth.
For ESPEasy I have setup some mirroring of static files for ESPEasy, like the CSS and JavaScript files so these don't have to be included in the already size limited builds.
The idea is that once you have those files loaded from those CDN servers, you don't need to reload them unless you cleared your browser cache.
There is also some "expiry date" set when serving those files. Typicall that's about 1 year.
So I guess some of those files are now no longer being served by those CDN servers and some users now hit this issue as the cached files now are considered "expired".
Thanks for your explanations!
I need to reread it to real understand I think.
-Bart
-Bart
