You have a few typos and syntax errors in your code:
- Syntax error: Any statement outside of and "on event do / endon" is ignored, so the let commands won't do anything
- Typo: "let2,0," won't work as expected
- Syntax error: "if if ..."
- Question: When is "on Ledweergave#State do" called?
I'm not sure why you are polling the GPIO pins, you'd better respond to an event once the state of a pin changes. That requires a complete rewrite of the code, but is more in the spirit of how an event system is intended to be used...
Checking the state and sending the status to Domoticz
can be handled in a single rule, making your code much more compact, another way to rewrite the code...
Your code with most issues fixed (no rewrite, yet
on Rules#Timer=1 do
if [Voordeur#Fails] < 7
Let,1,1
if [Plugin#GPIO#Pinstate#12]=0
Publish domoticz/in,'{"idx":1003,"svalue":"OPEN","nvalue":4}'
Publish domoticz/in,'{"idx":1003,"svalue":"DICHT","nvalue":1}'
else // [Voordeur#Fails] =>7
Let,1,0
Publish domoticz/in,'{"idx":1003,"svalue":"FOUT","nvalue":3}'
if [Achterdeur#Fails] < 7
Let,2,1
if [Plugin#GPIO#Pinstate#4]=0
Publish domoticz/in,'{"idx":1004,"svalue":"OPEN","nvalue":4}'
Publish domoticz/in,'{"idx":1004,"svalue":"DICHT","nvalue":1}'
else // [Achterdeur#Fails] => 7
Let,2,0
Publish domoticz/in,'{"idx":1004,"svalue":"PROBLEEM","nvalue":3}'
if [Slaapkamerdeur#Fails] < 7
Let,3,1
if [Plugin#GPIO#Pinstate#13]=0
Publish domoticz/in,'{"idx":1005,"svalue":"OPEN","nvalue":4}'
Publish domoticz/in,'{"idx":1005,"svalue":"DICHT","nvalue":1}'
else // [Slaapkamerdeur#Fails] >= 7
Let,3,0
Publish domoticz/in,'{"idx":1005,"svalue":"PROBLEEM","nvalue":3}'
if [Tuinkastdeur#Fails] < 7
Let,4,1
if [Plugin#GPIO#Pinstate#14]=0
Publish domoticz/in,'{"idx":1006,"svalue":"OPEN","nvalue":4}'
Publish domoticz/in,'{"idx":1006,"svalue":"DICHT","nvalue":1}'
else // [Tuinkastdeur#Fails] >= 7
Let,4,0
Publish domoticz/in,'{"idx":1006,"svalue":"PROBLEEM","nvalue":4}'
if [Schuurdeur#Fails] < 7
Let,5,1
if [Plugin#GPIO#Pinstate#15]=0
Publish domoticz/in,'{"idx":1007,"svalue":"OPEN","nvalue":4}'
Publish domoticz/in,'{"idx":1007,"svalue":"DICHT","nvalue":1}'
else // [Schuurdeur#Fails] >= 7
Let,5,0
Publish domoticz/in,'{"idx":1007,"svalue":"PROBLEEM","nvalue":4}'
//LED
On Ledweergave#State do
if [VAR#1]=1
GPIO,12,0//D6 voordeur
if [VAR#2]=1
GPIO,4,0//D2 achterdeur
if [VAR#3]=1
GPIO,13,0//D7 slaapkamer
if [VAR#4]=1
GPIO,14,0//D5 tuinkast
if [VAR#5]=1
GPIO,15,0//D8 schuurdeur
GPIO,16,0//D0 kleine poort
on System#Boot do
LoopTimerSet,1,45
Let,1,1
Let,2,1
Let,3,1
Let,4,1
Let,5,1
enddo
