ESPEasy v2.0.0-dev12 released
Re: ESPEasy v2.0.0-dev12 released
Well. After playing around this evening I've found:
1) Tried with another flasher (Silicon Labs CP210x USB to UART Bridge). Same result for 2.0.0-dev12 as with the FTDI adapter.
2) Tried to downgrade to 2.0.0-dev11 OTA. Flashing failed.
3) Using flasher, I loaded 2.0.0-dev11 onto one S20 and did the same config as I had before. I could not provoke it to fail.
4) Tried OTA upgrade to 2.0.0-dev12. Flashing failed.
Guess I'll just stay with dev11 for now. Let me know if I can be of any assistance in troubleshooting the problem.
OTA on a 1MBit ESP-01 will always fail!
The existing ESPEasy-2.0.0-dev11 and the new 2.0.0-dev12 added together is more then 1024KB.
As OTA has to download the binary completely befor it starts flashing there's just not enough memory for that.
See https://letscontrolit.com/wiki/index.php/ESPEasy the "2.0+ firmware on 1MB modules" chapter.
ok. That I should have spotted. Sorry for that. I (now) understand the OTA restrictions, but both should be able to flash from scratch on a 1MB module?Shardan wrote: ↑28 Sep 2017, 22:06 OTA on a 1MBit ESP-01 will always fail!
I've read about a new feature for uploading files in dev12.
Can someone tell me how it works?
The 1024-Binaries should definitely work on a 1MB module.
Be aware there are some ESP-01 (V3) modules that might cause trouble due to changed pinouts.
If i remember right this was mentioned somewhere in the forum already.
I'll see if i can test the 1024 binariy on ESP-01 this weekend
ok, so 2.0.0-dev12 should work on an Sonoff S20? Then I think something happened between dev11 and dev12, causing this issue.Shardan wrote: ↑29 Sep 2017, 13:04The 1024-Binaries should definitely work on a 1MB module.
https://github.com/letscontrolit/ESPEas ... .0.0-dev12
SightofSilence (1):
Add files via upload (#493)
SightofSilence (1):
I don't have S20 at hand so i can't test atm.
If i find some time this weekend i'll test with ESP-01 and possibly a Sonoff basic which is technically equivalent to the S20
I see no such thing as upload... https://github.com/letscontrolit/ESPEasy/pull/493ensingg wrote: ↑29 Sep 2017, 13:20 https://github.com/letscontrolit/ESPEas ... .0.0-dev12
SightofSilence (1):
I just types what you see on the first screen.
somebody used a wrong commit message, it should read 'Renamed and rearranged "Devices:" on info-page'.LisaM wrote: ↑29 Sep 2017, 14:48I see no such thing as upload... https://github.com/letscontrolit/ESPEasy/pull/493ensingg wrote: ↑29 Sep 2017, 13:20 https://github.com/letscontrolit/ESPEas ... .0.0-dev12
SightofSilence (1):
no new upload features, however with tools->flash you can already upload stuff.
shouldnt the ESP8285 version of the firmware be used for a sonof device?
ah our awesome wiki says the 1mb normal version should be ok indeed. https://www.letscontrolit.com/wiki/inde ... P_Hardware
I think the major issues is that recent Sonoff units (and apparently I've heard recent Wemos D1 mini unit as well) have a different flash chip and if the flash process is done in QIO mode (like we all have been doind so far) will end up in a non working module. The solution is to flash those modules in DIO mode; as well it seems that flashing in DIO mode will in theory free up 2 more GPIOs (9 and 10) but while 10 is reported to work perfectly, 9 is causing ESP8266 reboot (investigation lead to think it's due to some connection track to the flash no needed but still there in the PCB).psy0rz wrote: ↑04 Oct 2017, 17:15ah our awesome wiki says the 1mb normal version should be ok indeed. https://www.letscontrolit.com/wiki/inde ... P_Hardware
As well I've read other users reported that older Sonoff are behaving weird if flashed in DIO mode
Long story short, we should plan a new version of the flash tool that has the option to choose flash mode, either QIO or DIO.
For my problem with the S20 I think the device is 'as-usual' as espeasy boots & works pretty normal. It seems like when I put configuration on the device, then the error occurs. But only with dev12, not dev11.
As far as I can see TaskValueSet randomly triggers a reboot condition.
I am running dev-12 (4Mb version) on a NodeMCU. Directly after a reboot I initiate a default value (using rule 1).
As far as I can see this is always the trigger for the message "FS : Error while reading/writing config.dat in 926".
Then the device will either reboot directly again, or will keep working for a random time (the highest number I have seen in uptime is 736).
Each reboot takes place directly after executing a TaskValueSet command
Some more info:
- The device that is giving the problems:
* new nodeMCU, flashed with ESPEasy v2.0.0-dev12
* 2 x DS18b20
* 700 mAh poweradapter
I have currently 10 ESPEasy devices active (4 x NodeMCU, 4 x Sonoff S20, 1 x Wemos D1, 1 x Sonoff Basic), all running ESPEasy v2.0.0-dev12.
Only the device running a task that executes TaskValueSet does randomly reboot, all others are very stable.
Any hints to solve this?
On System#Boot do
TaskValueSet 3,1,0 // Zet de 1e param van dummy task #3 op 0
Oct 28 14:01:22 ESP Unit: 1 : WD : Uptime 288 ConnectFailures 0 FreeMem 18944
Oct 28 14:01:52 ESP Unit: 1 : WD : Uptime 288 ConnectFailures 0 FreeMem 18968
Oct 28 14:02:15 ESP Unit: 1 : DS : Temperature: 31.62 (28-ff-f1-f8-80-17-5-91)
Oct 28 14:02:15 ESP Unit: 1 : EVENT: CV-In#Temperature-In=31.62
Oct 28 14:02:15 ESP Unit: 1 : ACT : event InlaatTemperatuurOK
Oct 28 14:02:15 ESP Unit: 1 : EVENT: inlaattemperatuurok
Oct 28 14:02:15 ESP Unit: 1 : ACT : event PompKanAan
Oct 28 14:02:15 ESP Unit: 1 : EVENT: pompkanaan
Oct 28 14:02:15 ESP Unit: 1 : ACT : TaskValueSet 3,1,1
Oct 28 14:02:30 ESP Unit: 1 : WIFI : Connected! IP: 192.168.11.153 (Nodemcu-CV-ketel_1)
Oct 28 14:02:31 ESP Unit: 1 : EVENT: System#Boot
Oct 28 14:02:31 ESP Unit: 1 : ACT : TaskValueSet 3,1,0
Oct 28 14:02:31 ESP Unit: 1 : FS : Error while reading/writing config.dat in 926
Oct 28 14:02:31 ESP Unit: 1 : WD : Uptime 0 ConnectFailures 0 FreeMem 19032
Some more info:
* 2 x DS18b20
HansV wrote: ↑31 Oct 2017, 12:57 As far as I can see TaskValueSet randomly triggers a reboot condition.
I am running dev-12 (4Mb version) on a NodeMCU. Directly after a reboot I initiate a default value (using rule 1).As far as I can see this is always the trigger for the message "FS : Error while reading/writing config.dat in 926".Code: Select all
On System#Boot do TaskValueSet 3,1,0 // Zet de 1e param van dummy task #3 op 0 endon
Then the device will either reboot directly again, or will keep working for a random time (the highest number I have seen in uptime is 736).Each reboot takes place directly after executing a TaskValueSet commandCode: Select all
Oct 28 14:01:22 ESP Unit: 1 : WD : Uptime 288 ConnectFailures 0 FreeMem 18944 Oct 28 14:01:52 ESP Unit: 1 : WD : Uptime 288 ConnectFailures 0 FreeMem 18968 Oct 28 14:02:15 ESP Unit: 1 : DS : Temperature: 31.62 (28-ff-f1-f8-80-17-5-91) Oct 28 14:02:15 ESP Unit: 1 : EVENT: CV-In#Temperature-In=31.62 Oct 28 14:02:15 ESP Unit: 1 : ACT : event InlaatTemperatuurOK Oct 28 14:02:15 ESP Unit: 1 : EVENT: inlaattemperatuurok Oct 28 14:02:15 ESP Unit: 1 : ACT : event PompKanAan Oct 28 14:02:15 ESP Unit: 1 : EVENT: pompkanaan Oct 28 14:02:15 ESP Unit: 1 : ACT : TaskValueSet 3,1,1 Oct 28 14:02:30 ESP Unit: 1 : WIFI : Connected! IP: 192.168.11.153 (Nodemcu-CV-ketel_1) Oct 28 14:02:31 ESP Unit: 1 : EVENT: System#Boot Oct 28 14:02:31 ESP Unit: 1 : ACT : TaskValueSet 3,1,0 Oct 28 14:02:31 ESP Unit: 1 : FS : Error while reading/writing config.dat in 926 Oct 28 14:02:31 ESP Unit: 1 : FS : Error while reading/writing config.dat in 926 Oct 28 14:02:31 ESP Unit: 1 : FS : Error while reading/writing config.dat in 926 Oct 28 14:02:31 ESP Unit: 1 : FS : Error while reading/writing config.dat in 926 Oct 28 14:02:31 ESP Unit: 1 : FS : Error while reading/writing config.dat in 926 Oct 28 14:02:31 ESP Unit: 1 : WD : Uptime 0 ConnectFailures 0 FreeMem 19032
Some more info:
* 2 x DS18b20
I'm getting the "Error while reading/writing config.dat in 926" with just:
in my rules . See it on different devices.on onoff#push=1 do
if [relay#Switch]=1
gpio,12,0
gpio,12,1
Same here. Getting ""Error while reading/writing config.dat" for every rule that has an if statement. I'm running a bunch for Wemos D1's and ESP-12's.I'm getting the "Error while reading/writing config.dat in 926" with just:
on onoff#push=1 do
if [relay#Switch]=1
gpio,12,0
gpio,12,1
Please report on GitHub.
Had the same. Just make a reset and config the ESP from scratch (no config restore to be sure!). After that:
Rule:
on Button#State do
if [Button#State]=1
event switchon
event switchoff
[Submit]
Log:
197926 : FILE : Saved config.dat
197951 : FILE : Saved security.dat
Rule:
on Button#State do
if [Button#State]=1
event switchon
event switchoff
[Submit]
Log:
I've configured a "blank" ESP-12E for my dust sensor prototype with 2.0.0-DEV12 TESTING, sources Oct.25. '17.
No issues even with a lot of rules.
I'm able to reproduce this across different ESP8266 based products: Sonoff Basic, Sonoff S20, Sonoff TH16 & Wemos D1 mini pro.
My settings are:
- Various names for the device, e.g. "Garden light east"
- Different Unit ID's (e.g. 95, 128, 136)
- Static IP address
- OpenHAB MQTT with IP address
- NTP server set to IP addess
- Two devices configured: Button & Relay GPIO's
To me it seems like when the rule(s) become too long, the error occurs. I cannot reproduce at all with dev11.
Edit: Most tests have been performed with freshly flashed devices. Have also tried the 'reset' command, and starting all-over. Same result.
My settings are:
- Static IP address
This rule:
If I change it to:
If I change it to:
If I change it to:
Seems to me, that it could be related to the size of the rule.
results in the 'FS : Error while reading/writing config.dat in 926" error on one Sonoff TH10, but not on another TH10. Settings are identical (besides the obvious IP, device ID etc.).On System#Boot do //When the ESP boots, do
publish %sysname%/sysname,%sysname%
publish %sysname%/IP,%ip%
publish %sysname%/relay/Switch,[relay#Switch]
timerSet,1,60 //Set Timer 1 for the next event in 30 seconds
On Rules#Timer=1 do //When Timer1 expires, do
timerSet,1,60 //Resets the Timer 1 for another 30 seconds
If I change it to:
then it works.On System#Boot do //When the ESP boots, do
If I change it to:
I get the error on the same module, but not the other.on onoff#push=1 do
if [relay#Switch]=1
gpio,12,0
gpio,12,1
If I change it to:
then no error.on onoff#push=1 do
Users browsing this forum: No registered users and 99 guests
