Control relay with physical locally button
Hi Guys
I'use with success an relay with esp8266 + domoticz for controlling dry contact, I need to add a button locally like press physical button and relay change state without need network access, the best will be updated status in domoticz....
Not sure how to do that, if somebody as already experienced this kind of setup ?
Regard, Vic
Regard, Vic
- budman1758
Re: Control relay with physical locally button
There are a few ways to make that happen. Mostly depends on your hardware. If you want a pushbutton switch you will need to set it up on another GPIO and set up a rule to toggle the relay. If using a on-off switch you can probably use it to control the relay and set up a task on the GPIO that controls the relay that monitors the high or low state of the pin.
The Wiki is your friend.....
https://www.letscontrolit.com/wiki/inde ... rial_Rules
https://www.letscontrolit.com/wiki/index.php/Switch
Ok I attached Momentary Button and expect toggle between on/off switch relay, any clue for rules ?
Budman gave you the correct link.... But since you missed the info anyway, here you go - direct link : https://www.letscontrolit.com/wiki/inde ... long_press
I tried with this rules:
nothing work!
Here's my setup:
Device1
Device: Switch input
Delay: 0
IDX/Var: 1
1st GPIO: GPIO-15
Pull UP: Yes
Inversed: No
Switch Type: Switch
Switch Button Type: Normal Switch
Send Boot State: Yes
Send Data: Yes
Value Name 1: Switch
Device2
Delay: 0
IDX/Var: 150
1st GPIO: GPIO-2
Pull UP: Yes
Inversed: No
Switch Type: Switch
Send Boot State: No
Send Data: No
on Button#Status=1 do
if [Relay#Status]=0
gpio,15,0
gpio,15,1
Here's my setup:
Device1
Delay: 0
IDX/Var: 1
1st GPIO: GPIO-15
Pull UP: Yes
Inversed: No
Switch Type: Switch
Send Data: Yes
Device2
Delay: 0
IDX/Var: 150
1st GPIO: GPIO-2
Pull UP: Yes
Inversed: No
Switch Type: Switch
Send Boot State: No
Send Data: No
on Button#Status do
if [Button#Status]=1
gpio,15,0
gpio,15,1
tks Grovkillen for your help, rule doesn't work
I should see in the log rule started ?
2180454 : WD : Uptime 36 ConnectFailures 0 FreeMem 22048
2185128 : SW : State 0
2185128 : EVENT: Button#Button=0.00
2186744 : SW : State 1
2186744 : EVENT: Button#Button=1.00
2198148 : SW : State 0
2198149 : EVENT: Button#Button=0.00
2199865 : SW : State 1
2199865 : EVENT: Button#Button=1.00
2210455 : WD : Uptime 37 ConnectFailures 0 FreeMem 22048
You are naming the value "button" as well! Change value name to "status" as stated in the rule.
PS: GPIO 15 is not the best to use with relays (https://www.letscontrolit.com/wiki/inde ... figuration)
Awsome it's working, many tks Grovkillen.
So where I put the request for update the status in domoticz? something like that
SendToHTTP 10.0.0.18:8080/json.htm?type=command¶m=udevice&idx=55&nvalue=1
I'm not a Domoticz user but yes you may use a http command.
I have a strange character after "command" in the log and of course doesn't work
15878769 : ACT : gpio,15,1
15878771 : SW : GPIO 15 Set to 1
15878776 : ACT : SendToHTTP 10.0.0.18:8080/json.htm?type=command¶m=udevice&idx=55&nvalue=0
- budman1758
Try this as your sendto.....
SendToHTTP 10.0.0.18,8080,/json.htm?type=command¶m=udevice&idx=55&nvalue=0
found in the wiki rules turnaround where is said to use this syntax I tried but nothing update in domoticz and
unfortunately I just want update the status not toggle the switch
SendToHTTP 10.0.0.0,8080,/json.htm?type=param=switchlight&command&idx=55&switchcmd=On
I do not think that you can update switch status without actually switching it...
Perhaps you can use Selector switch in domoticz, with different actions at different levels, or you can update a User variable, that you can manage in the Domoticz side in LUA.
In LUA then you can use "UpdateDevice".
yeah, got it working just use this syntax and all good
SendToHTTP 10.0.0.18,8080,/json.htm?param=udevice&type=command&idx=55&nvalue=1
Put it next line after you change gpio status.
But I use different command:
You mus send command for report "off" status too
SendToHTTP 192.168.1.253,8080,/json.htm?type=command¶m=switchlight&idx=26&switchcmd=On
SendToHTTP 192.168.1.253,8080,/json.htm?type=command¶m=switchlight&idx=26&switchcmd=Off
Users browsing this forum: Bing [Bot] and 117 guests
