Hello EveryOne,
My firt name is Gabriel.
I develop my domotic with Domoticz.
I've tried wired systems, 433Mhz and NRF24L01. But I don't know if my haouse was hunted, but nor DI.O (chaccon systems) they don't work perfectly.
So, I've decided to use a comfortabe network system : WIFI.
And the ESP8266 Be !!
With EspEasy & Domoticz, I can make a beautyful domotic system.
But I'm a mad developper and I already have Modified EspEasy :
- Correction for the Dallas 18B20 and add the resolution choice
- Add a relay plugin, for use with normal relay and Low state actived relay.
- working , to develop a plugin for the shift register 74HC595, but this task need to modify the core of EspEasy (add a third pin to the device structure)
Is there an other version than the R38 ? (before I' send to you my work)
Thank you a lot for your work.
Best regards
Gabriel
Hello EveryOne.
Re: Hello EveryOne.
Hi, welcome here.
If you go to the github, you will find the latest versions.
Re: Hello EveryOne.
Yes,
Ok...
Thank's for the answer....i see that after my post....oups !
Ok...
Re: Hello EveryOne.
Oh , I Forgot....I'm French. Also if my english isn't perfect, it's totaly normal.
here is my version of the P004 plugin for the dallas DS18b20 :
The code is in attachment.
- _P004_Dallas.zip
- (4.32 KiB) Downloaded 296 times
Re: Hello EveryOne.
With the screen capture :
[attachment=0]Capture.jpg[/attachment]
- Capture.jpg (130.31 KiB) Viewed 4727 times
