Sonoff 4CH with ESPEasy
Re: Sonoff 4CH with ESPEasy
#101 Post by grovkillen » 02 Dec 2017, 21:22
stofakiller wrote: 21 Sep 2017, 15:07 Hi,
I have a 5-32v Sonoff/Itead 4ch, but i cant figure out how to flash it. I have flash many types of Sonoff's, i have Sonoff POW, normal 1ch Sonoffs and bulbs... I have triede both thrue my Arduino to flash it and also tried to erase it with ESP_Basic_Flasher... I always get cant open the port. Anyone triede or have any suggestions?
This unit is now "officially" supported by ESP Easy: https://www.letscontrolit.com/wiki/inde ... ff_DIY_4ch
manjh
#102 Post by manjh » 12 Dec 2017, 16:22
Any chance of formal support for the Sonoff Pow? Looks like a very handy little device to help understand power consumption...
#103 Post by grovkillen » 12 Dec 2017, 17:04
manjh wrote: 12 Dec 2017, 16:22 Any chance of formal support for the Sonoff Pow? Looks like a very handy little device to help understand power consumption...
Since Tasmota is supporting that device it should be possible to write a plugin for ESP Easy as well. If you do some research on the subject and bring all your findings and suggest a enhancement on GitHub someone might pick up the idea.
#104 Post by Shardan » 12 Dec 2017, 20:10
There's already a long thread about sonoff pow in the forum.
http://www.letscontrolit.com/forum/view ... POW#p20950
manjh
#105 Post by manjh » 12 Dec 2017, 20:46
Shardan wrote: 12 Dec 2017, 20:10
I noticed, and managed to read half way through it.
At some point the discussion drifted off towards liability and how people will try to electrocute themself. :twisted:
I was hoping to find a firm "yes" or "no" answer to the support question, or (if that can't be given) perhaps a careful "maybe in the near future"...
manjh
#106 Post by manjh » 12 Dec 2017, 20:48
grovkillen wrote: 12 Dec 2017, 17:04
Ah, yes... :oops:
Unfortunately I am more of a tester than a developer these days... I'm sure I would eventually even be able to write a plugin, but the learning curve would be a bit steep! :)
#107 Post by grovkillen » 12 Dec 2017, 21:30
manjh wrote: 12 Dec 2017, 20:48
Ah, yes... :oops:
But you can always do something, like finding places where to find more information etc. Links are valuable assets.
papperone
#108 Post by papperone » 13 Dec 2017, 07:37
What do you mean? I already wrote a plugin to support POW current/voltage reading feature.
The relay and led can be activated with standard plugin, what else you need?
manjh
#109 Post by manjh » 13 Dec 2017, 08:45
papperone wrote: 13 Dec 2017, 07:37
:) :) :) you just made my day! :) :) :)
This information is probably somewhere in the seond half of that long thread, which I have not read yet. I also checked the Wiki, found a number of Sonoff products that are supported but did not see any reference to the pow.
Can I assume the plugin is in Github?
papperone
#110 Post by papperone » 13 Dec 2017, 17:34
manjh wrote: 13 Dec 2017, 08:45
Yes, it's in the playground still but fully functional...
manjh
#111 Post by manjh » 13 Dec 2017, 17:37
papperone wrote: 13 Dec 2017, 17:34
Great. Now I will have to figure out how to get it from that "playground", and compile....
For the time being, I am using the Sonoff with their app. Works great, but not integrated with other devicecs via Domoticz.
nekely
#112 Post by nekely » 16 Jan 2018, 23:19
I have managed to operate the sonoff 4ch correctly, with ESP, what I do not get is that none of the physical buttons work.
manjh
#113 Post by manjh » 16 Jan 2018, 23:45
nekely wrote: 16 Jan 2018, 23:19 I have managed to operate the sonoff 4ch correctly, with ESP, what I do not get is that none of the physical buttons work.
You need to create rules for that.
Example:
On TurnOn1 do
  gpio, 12, 1
On TurnOff1 do
  gpio, 12, 0
On TurnOn2 do
  gpio, 5, 1
On TurnOff2 do
  gpio, 5, 0
On TurnOn3 do
  gpio, 4, 1
On TurnOff3 do
  gpio, 4, 0
On TurnOn4 do
  gpio, 15, 1
On TurnOff4 do
  gpio, 15, 0
on Toggle1 do
  if [relais1#state]=1
    Event TurnOff1
    Event TurnOn1
on Toggle2 do
  if [relais2#state]=1
    Event TurnOff2
    Event TurnOn2
on Toggle3 do
  if [relais3#state]=1
    Event TurnOff3
    Event TurnOn3
on Toggle4 do
  if [relais4#state]=1
    Event TurnOff4
    Event TurnOn4
on button1#state do
  Event Toggle1
on button2#state do
  Event Toggle2
on button3#state do
  Event Toggle3
on button4#state do
  Event Toggle4
nekely
#114 Post by nekely » 17 Jan 2018, 10:27
sorry ..., I had not restarted the sonoff. :?
now it works, but only the first time it turns on and off, then I press the button and it does not do anything
manjh
#115 Post by manjh » 17 Jan 2018, 10:45
nekely wrote: 17 Jan 2018, 10:27 sorry ..., I had not restarted the sonoff. :?
can you show the rules and device settings?
nekely
#116 Post by nekely » 17 Jan 2018, 20:07
this is the rule
On Channel1#Switch do
    if [Channel1#Switch]=1
        event,Channel1_On
        event,Channel1_Off
On Channel2#Switch do
    if [Channel2#Switch]=1
        event,Channel2_On
        event,Channel2_Off
On Channel3#Switch do
    if [Channel3#Switch]=1
        event,Channel3_On
        event,Channel3_Off
On Channel4#Switch do
    if [Channel4#Switch]=1
        event,Channel4_On
        event,Channel4_Off
on Channel1_On do
    gpio,12,1
    inputswitchstate 0,1
on Channel1_Off do
    gpio,12,0
    inputswitchstate 0,0
on Channel2_On do
    gpio,5,1
    inputswitchstate 9,1
on Channel2_Off do
    gpio,5,0
    inputswitchstate 9,0
on Channel3_On do
    gpio,4,1
    inputswitchstate 10,1
on Channel3_Off do
    gpio,4,0
    inputswitchstate 10,0
on Channel4_On do
    gpio,15,1
    inputswitchstate 14,1
on Channel4_Off do
    gpio,15,0
    inputswitchstate 14,0
#117 Post by TD-er » 17 Jan 2018, 20:11
What version of ESPeasy?
I recently (last week) fixed an issue with the switch plugin.
nekely
#118 Post by nekely » 17 Jan 2018, 20:25
version 2_3_0
#119 Post by grovkillen » 17 Jan 2018, 20:56
nekely wrote: 17 Jan 2018, 20:25version 2_3_0
That is the core version. What ESP Easy version?
manjh
#120 Post by manjh » 17 Jan 2018, 21:29
In the first piece of code, you're checking on the state of the switch. Should be the state of the gpio.
nekely
#121 Post by nekely » 17 Jan 2018, 21:50
I just put the last update today, I'll try it
nekely
#122 Post by nekely » 17 Jan 2018, 22:07
nothing, with the new update they do not work either
nekely
#123 Post by nekely » 20 Jan 2018, 13:27
manjh wrote: 17 Jan 2018, 21:29 In the first piece of code, you're checking on the state of the switch. Should be the state of the gpio.
I'm sorry I did not see this message, I try it
tplus
#124 Post by tplus » 21 Jan 2018, 21:02
Is there an IO-mapping for the Sonoff 4CH PRO available?
Thanks for help...
nekely
#125 Post by nekely » 23 Jan 2018, 13:13
in the end I got it, thanks
at first pressing the button would turn on, but turning it off at the time it was turned on again.
After several tests I got it to work changing "normal switch" to "push button active low"
these are the rules that you create
on Boton1#Switch do
if [Boton1#Switch]=1
gpio,12,0
gpio,12,1
on Boton2#Switch do
if [Boton2#Switch]=1
gpio,5,0
gpio,5,1
on Boton3#Switch do
if [Boton3#Switch]=1
gpio,4,0
gpio,4,1
on Boton4#Switch do
if [Boton4#Switch]=1
gpio,15,0
gpio,15,1
now all switch works fine, I just need to try it with my veraedge
tplus
#126 Post by tplus » 23 Jan 2018, 17:52
I tried to find the GPIO IO-mapping for the 4CH Pro using HTTP commands. At GPIO-6 relay one got on but I could not switch it off again. Tried also to switch on GPIO 4 and 5. Then I could not connect to the GUI any more and now the 4CH Pro is in a boot-loop:
INIT : Booting version: v2.0-20180120
INIT : Cold Boot
FS   : Mounting...
FS   : Mount successful, used 75802 bytes of 113201
INIT : Free RAM:26000
INIT : I2C
INIT : SPI not enabled
WIFI : AP Mode disabled
WIFI : AP Mode ssid will be ESP_water_0 with address 192.168.4.1
WIFI : Connecting XXXX attempt #1
WIFI : Connected! IP: 192.168.10.35 (ESP_water_0)
 ets Jan  8 2013,rst cause:4, boot mode:(3,0)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
⸮U
INIT : Warm boot #1
FS   : Mounting...
INIT : I2C
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
⸮U
When I change the onboard "Work Mode Switch" from "Interlock" to "Self-locking/Inching" it's still in a loop but the boot mode changes to (3,2). Also the top 3 LED are on.
Installed software v2.0-20180123, no change.
What to do? Is there a "GPIO of death"?
Thanks for some help.
nekely
#127 Post by nekely » 24 Jan 2018, 20:10
nekely wrote: 23 Jan 2018, 13:13 now all switch works fine, I just need to try it with my veraedge
Works fine with my veraedge, send de command and status correctly modifing some the rules to send htpp commands
tplus
#128 Post by tplus » 26 Jan 2018, 17:11
Sonoff 4CH Pro:
GPIO mapping is the same. All K5 switches should be set to "on", the S6 switch to 1. Then it works like the standard one.
radebebek
#129 Post by radebebek » 05 Feb 2018, 11:10
radebebek
#130 Post by radebebek » 05 Feb 2018, 11:13
Hello All,
I have this scheme wiring: http://prntscr.com/i0qrfb
I used homebridge plugin and iphone app HOME and I have problem about inform state.
Example:
1. State Lights on HOME app is OFF.
2. Turn on Lights with HOME app on R1 relay, snd Sonoff PRO switch reley and Lights is ON. On app HOME change state to ON.
3. When I pressing physical key "WALL SWITHC" Disconnect Electric Cricuit and turn off Light.
State continue ON on HomeAPP.
How to inform app that state is change?
Is there firmware has this possibility?
Rade
Methuselah
#131 Post by Methuselah » 05 Feb 2018, 16:00
Greetings folks.
Has anyone attempted to solder an I-PEX connector on PSF-A's wifi antenna solder traces?
I need to install my Sonoff outside, in a weatherproof electrical enclosure which will attenuate the wifi signal. I can drill a hole and install an SMA barrel connector, and place an wifi antenna on the exterior of the enclosure, and run a I-PEX cable to the Sonoff, but need to solder a I-PEX female connector to the PSF-A board
Assuming this will work... wondering if anyone has tried it.
N00b to the world of ESPEasy, but I've been programming since the days of punch cards and paper tape :)
Domosapiens
#132 Post by Domosapiens » 06 Feb 2018, 01:01
I-PEX and PSF-A :? :?
Could this solve you problem?
https://nl.aliexpress.com/item/1set-2-4 ... 04091.html
Methuselah
#133 Post by Methuselah » 06 Feb 2018, 13:43
Pretty much what I was going to do...
but requires the male connector soldered to the traces on the chip...
was wondering if anyone has attempted or done it already. I've ordered everything I need off amazon, should be here friday.
Methuselah
#134 Post by Methuselah » 09 Feb 2018, 18:10
Was a little tough to get the I-PEX connector soldered on (I had to order a different set of tips for my Weller), but I managed to do it, and it works great. After soldering on the connector, you can check if it is seated correctly by testing connectivity between the antenna pin (marked in red) and the center conductor on the I-PEX connector. The outer ring connects to ground, so just test connectivity between it and any ground on the motherboard. I connected a pigtail and secured it with some hot glue to the motherboard so it would not work itself loose. I then drilled a hole through the side of the Sonoff case and mounted the SMA connector. I connected a spare wifi antenna, but, when I mount it in the electrical enclosure outside, I will use an SMA extension cable through a drilled hole in the enclosure itself and mount the antenna on the outside of the cabinet.
Domosapiens
#135 Post by Domosapiens » 09 Feb 2018, 18:19
Good job!
#136 Post by grovkillen » 09 Feb 2018, 18:20
Yes, looks very sharp. Good job!
Methuselah
#137 Post by Methuselah » 20 Feb 2018, 18:39
Final installation:
left-upper unit is wired to a 4-port VHF antenna switch on my tower, which uses 12vdc on 3 different pins to select which port (no voltage = port 1). I've programmed it to accept different commands to select which port on the switch to choose, e.g. /ip/control?cmd=event,Antenna3 will flip relay 3 to select port 4 on the switch.
upper-right unit is wired to an 8-port HF antenna switch (Ameritron RCS-10) which uses 12vdc BCD logic on 3 pins to select a port (000 = port 1, 111 = port 7, etc.) Again, programmed some commands, e,g, /ip/control?cmd=event,Antenna4 to turn on and off the appropriate relays via GPIO to select the correct port.
This allows me to run 2 line of Andrews LDF6-50 (~250' each) from my shack to the tower base, rather than a different run for each antenna (mega $$$$ - $10+/foot), and I can select which antenna I want to operate off of via a web command.
The bottom sonoff is used to control a winch to automatically raise and lower the tower fixture (a TX-455 crank up, retrofitted with a KF9P hoist plate and harbor freight 2000 lb hoist (see https://www.youtube.com/watch?time_cont ... TQiq-WGNFE). One relay is used to power on and off the hoist w/ 120vac (switching the hot wire), and two relays are used to select up or down motion (by directing current to one of two wires).
#138 Post by TD-er » 21 Feb 2018, 00:25
And the sonoff's are not interfering with the antenna signal itself?
Hope you're not switching to much current with these sonoffs. Even though they are rated for up to 10 Amps (some even 16 Amps), I wouldn't let them switch currents even half those limits.
Methuselah
#139 Post by Methuselah » 21 Feb 2018, 15:07
TD-er wrote: 21 Feb 2018, 00:25 And the sonoff's are not interfering with the antenna signal itself?
No. They switch relays which control an RF path from an input source to an output port. No RF travels through the Sonoff. It simply provides a 12vdc current source to the switching relays (not the unit I have, but along the same principle):
The antenna switches themselves use about 1/3rd of an amp to control the switching logic. The hoist uses a couple of amps to raise and lower the tower -- the hoist is significantly oversized for my application, but that's what the manufacturer of the hoist plate recommends (he sells one plate which will work with towers ranging from 40 to 90 feet, so the hoist in question is really designed for a tower twice the height of mine.) I expect it to draw about 3-5 amps maximum.
Mazzokun
#140 Post by Mazzokun » 28 Mar 2018, 10:10
Hi all!
I'have flashed Sonoff 4ch with EspEasy v2.0-20180322, connected to domoticz and all works very well.
I connected a Pulse counter (TCRT5000 https://it.aliexpress.com/item/Free-shi ... lsrc=aw.ds) to GPIO2 on the board and followed the wiki https://www.letscontrolit.com/wiki/index.php/LJ12A3 but it doesn't work. Anyone can help? Thank you
#141 Post by grovkillen » 28 Mar 2018, 10:21
What task number is the pulse counter on? Only 1..4 is allowed.
Mazzokun
#142 Post by Mazzokun » 28 Mar 2018, 14:48
Ok now with task 4 it reads the values...
but if I power cycle Sonoff it does not boot up if the tctr5000 Digital Output is connected to GPIO2..
If I connect TCTR to GPIO2 after the sonoff is boot up, all works.
What can I do?
Thank you
#143 Post by grovkillen » 28 Mar 2018, 15:04
https://www.letscontrolit.com/wiki/inde ... figuration
It need to be high on boot so please see if it's possible to activate a pull-up or you might need to fix a external pull-up.
Mazzokun
#144 Post by Mazzokun » 28 Mar 2018, 20:18
I soldered a 4.7k resistance between 3.3v and gpio2 but it does not work.
I tried to use the gpio13 of the led of the wifi but during the start the relay 4 turns on and off immediately ..
Where did I go wrong?
#145 Post by grovkillen » 28 Mar 2018, 20:30
Can you measure what the TCRT5000 is delivering to GPIO 2? I mean, can it be that it pulls the voltage down still even with the pull-up?
I'm no electronics guy so I'm just throwing stuff here...
Mazzokun
#146 Post by Mazzokun » 29 Mar 2018, 10:24
I'have found out that if I cover the IR led during the start up of sonoff it doesn't boot up (green led of TCRT is on) DO on tcrt is 3.3v .
If I don't cover it (green led on tcrt is off) DO on tcrt is 3.3v than Sonoff boot up...
But it's always green and it's off when it pulse.. so the problem persist..
I have connected DigitalOutput to the Sonoff but I have also an AnalogicOutput..
That's all. Thank you for support :)
#147 Post by grovkillen » 29 Mar 2018, 10:46
Ah, yes I always cover the IR led if I'm not using it as a signal. Great, I had my thoughts that something like that was going on :)
EDIT: or am I misunderstanding you (feels like it)?
Mazzokun
#148 Post by Mazzokun » 29 Mar 2018, 11:06
yes, you misunderstood me, sorry for my little English :lol:
as an experiment I cover the two Led and if they are covered the esp doesn't boot, if they are not covered the esp boot up.
so I misured DO signal.. it's 3.3v if the led is covered and 0v if it's free..
I use the tcrt to read the number of spins of an old water meter
#149 Post by TD-er » 29 Mar 2018, 20:01
Just to be sure... it is just about the LEDs on the Sonoff 4ch, without any other components added?
A LED may act as a "solar panel".
You can verify this with a multimeter and a LED. Any led will work.
The voltage generated by the LED can be > 2V, depending on the color of the LED.
With the slightest load the voltage will drop to 0, since power generated is low, but on a high impedance input it may set some input off.
Activating a pull-up resistor may help then.
The_knarf
#150 Post by The_knarf » 21 Apr 2018, 15:28
Hi all,
i am using the sonoff 4ch now for half a year with the default software, but i don't like that my switch is controlled via internet.
can i use ESPEasy to switch the 4 channels on/off? or does ESPEasy need to be controlled via a server/broker/MQTT?
I am looking for a solution to just have an app or webpage on my android phone to switch the 4 channels on or off. for now that would be all, who knows maybe later i will also use a broker or what ever.
I successfully loaded ESPEasy on it, but whats next, i dont see a page to control the switches, anybody a sugestion for this NOOB?
Thanks in advanced,
btw, i installed the ESPEasy_R148a_1024.zip posted by Shardan on page 4
