This device uses a select dip switch with 8 values on/off
The cpu onboard is M1E G982
Any idea about another compatible protocol ?
Is it possible to add manually it with another protocol ??
Below, what I get from RfLink Debug:
With switch 00000000
2017-12-17 16:57:49.702 RFLink: 20;E9;DEBUG;Pulses=26;Pulses(uSec)=480,900,390,900,420,900,390,900,420,900,390,900,420,900,390,900,420,900,420,900,390,390,900,390,900,6990;
2017-12-17 16:57:49.775 RFLink: 20;EA;DEBUG;Pulses=26;Pulses(uSec)=480,900,420,900,420,900,390,900,420,900,390,900,420,900,390,900,420,900,390,900,420,390,900,390,900,6990;
2017-12-17 16:57:49.846 RFLink: 20;EB;DEBUG;Pulses=26;Pulses(uSec)=480,900,420,900,420,900,420,900,390,900,420,900,390,900,420,900,420,900,390,900,420,390,900,390,900,6990;
2017-12-17 16:57:49.919 RFLink: 20;EC;DEBUG;Pulses=26;Pulses(uSec)=480,900,420,900,390,900,420,900,390,900,420,900,390,900,420,900,390,900,420,900,390,390,900,390,900,6990;
2017-12-17 16:57:49.989 RFLink: 20;ED;DEBUG;Pulses=26;Pulses(uSec)=480,900,390,900,420,900,390,900,420,900,390,900,420,900,420,900,390,900,420,900,390,390,900,390,900,6990;
2017-12-17 16:57:50.062 RFLink: 20;EE;DEBUG;Pulses=26;Pulses(uSec)=480,900,390,900,420,900,390,900,420,900,390,900,420,900,420,900,420,900,390,900,420,390,900,390,900,6990;
switch 10000000
2017-12-17 17:10:37.615 RFLink: 20;11;DEBUG;Pulses=26;Pulses(uSec)=600,420,900,900,390,900,390,900,390,900,390,900,390,900,390,900,390,900,390,900,390,420,900,390,900,6990;
2017-12-17 17:10:37.689 RFLink: 20;12;DEBUG;Pulses=26;Pulses(uSec)=390,420,900,900,390,900,390,900,390,900,390,900,390,900,390,900,390,900,390,900,390,420,900,390,900,6990;
Switch 11000000
2017-12-17 17:11:38.206 RFLink: 20;16;DEBUG;Pulses=26;Pulses(uSec)=420,420,900,420,900,900,390,900,390,900,390,900,390,900,390,900,390,900,390,900,390,390,900,420,900,6990;
2017-12-17 17:11:38.276 RFLink: 20;17;DEBUG;Pulses=26;Pulses(uSec)=180,960,900,420,900,900,390,900,390,900,390,900,390,900,390,900,390,900,390,900,390,420,900,420,900,6990;
Switch 11100000
2017-12-17 17:12:42.055 RFLink: 20;22;DEBUG;Pulses=24;Pulses(uSec)=960,420,900,390,900,900,390,900,390,900,390,900,390,900,390,900,390,900,390,390,900,420,900,6990;
2017-12-17 17:12:42.128 RFLink: 20;23;DEBUG;Pulses=24;Pulses(uSec)=960,420,900,420,900,900,390,900,390,900,390,900,390,900,390,900,390,900,390,390,900,420,900,6990;
2017-12-17 17:12:42.202 RFLink: 20;24;DEBUG;Pulses=24;Pulses(uSec)=960,420,900,420,900,900,390,900,390,900,390,900,390,900,390,900,390,900,390,420,900,420,900,6990;
2017-12-17 17:13:58.875 RFLink: 20;38;DEBUG;Pulses=26;Pulses(uSec)=600,420,900,420,900,420,900,420,900,420,900,420,900,390,900,420,900,900,390,900,390,390,900,420,900,6990;
2017-12-17 17:13:58.948 RFLink: 20;39;DEBUG;Pulses=26;Pulses(uSec)=210,900,900,420,900,420,900,390,900,420,900,390,900,420,900,390,900,900,390,900,390,420,900,420,900,6990;
2017-12-17 17:13:59.019 RFLink: 20;3A;DEBUG;Pulses=26;Pulses(uSec)=450,900,900,420,900,420,900,420,900,420,900,390,900,420,900,390,900,900,390,900,390,420,900,390,900,6990;
2017-12-17 17:13:59.092 RFLink: 20;3B;DEBUG;Pulses=26;Pulses(uSec)=210,900,900,420,900,420,900,420,900,390,900,420,900,390,900,420,900,900,390,900,390,420,900,390,900,6990;
If you need more tests, let's me know.
Now waiting for a new release with this device supported
Keep up the great work !!
