In a nutshell, I use the 4CH to manually cycle on heating zones in my house regardless of what the household thermostats say (long story short is house is 300 years old, and forced hot water lines sometimes freeze in extremely cold temps because the temps near the pipes are much colder than where the thermostat is... so by manually running the circulator and opening those zone valves, I can flush water through the line and keep the pipes from freezing). I also push some interior and exterior temps from weather stations to the 4CH to aid in making decisions on what to do.
In my rules, I use MQTT to publish status messages from my script so I can remotely monitor what the device is doing.
The problem I am encountering is the MQTT connection repeatedly bounces up and down. Mosquitto reports (Windows version):
1518875355: New connection from 192.168.102.4 on port 1883.
1518875355: New client connected from 192.168.102.4 as ESPClient_DC:4F:22:80:1D:49 (c1, k15, u'').
1518875355: Sending CONNACK to ESPClient_DC:4F:22:80:1D:49 (0, 0)
1518875355: Received SUBSCRIBE from ESPClient_DC:4F:22:80:1D:49
1518875355: fg/out (QoS 0)
1518875355: ESPClient_DC:4F:22:80:1D:49 0 fg/out
1518875355: Sending SUBACK to ESPClient_DC:4F:22:80:1D:49
1518875355: Sending PUBLISH to ESPClient_DC:4F:22:80:1D:49 (d0, q0, r1, m0, 'fg/out', ... (9 bytes))
1518875355: Received PUBLISH from ESPClient_DC:4F:22:80:1D:49 (d0, q0, r1, m0, 'fg/out', ... (9 bytes))
1518875355: Sending PUBLISH to ESPClient_DC:4F:22:80:1D:49 (d0, q0, r0, m0, 'fg/out', ... (9 bytes))
1518875370: Received PINGREQ from ESPClient_DC:4F:22:80:1D:49
1518875370: Sending PINGRESP to ESPClient_DC:4F:22:80:1D:49
1518875385: Received PINGREQ from ESPClient_DC:4F:22:80:1D:49
1518875385: Sending PINGRESP to ESPClient_DC:4F:22:80:1D:49
1518875407: Client ESPClient_DC:4F:22:80:1D:49 has exceeded timeout, disconnecting.
1518875407: Socket error on client ESPClient_DC:4F:22:80:1D:49, disconnecting.
1518875415: New connection from 192.168.102.4 on port 1883.
(cycle repeats)
I have a fair amount of rules (to process button pushes) as well as running 3 timers to control 3 of the relays on/off cycles. The timers run anywhere from 5 to 60 minutes.
According to the main page, my system load varies between 12 to 80%, depending on what is going on -- it seems when the MQTT timeouts occur, system load is considerably higher, probably as the software attempts to go through the reconnection/negotation logic.
Capturing debugging output to a syslog server, I get:
EVENT: SetOutsideTemp=30.3
ACT : TaskValueSet 9,1,30.3
EVENT: Processing time:2555 milliSeconds
WD : Uptime 1243 ConnectFailures 125 FreeMem 19984
Dummy: value 1: 30.30
Dummy: value 2: 0.00
Dummy: value 3: 0.00
Dummy: value 4: 0.00
EVENT: Outside#Temp=30.30
EVENT: Processing time:2374 milliSeconds
EVENT: Outside#Humidity=0.00
EVENT: Processing time:2370 milliSeconds
EVENT: Outside#Barometer=0.00
EVENT: Processing time:2377 milliSeconds
EVENT: Outside#Flag=0.00
EVENT: Processing time:2373 milliSeconds
Dummy: value 1: 41.70
EVENT: Inside#Temp=41.70
EVENT: Processing time:2548 milliSeconds
EVENT: Inside#=0.00
EVENT: Processing time:2536 milliSeconds
EVENT: Inside#=0.00
EVENT: Processing time:2539 milliSeconds
EVENT: Inside#=0.00
EVENT: Processing time:2540 milliSeconds
EVENT: Clock#Time=Sat,14:08
EVENT: Processing time:2541 milliSeconds
WD : Uptime 1243 ConnectFailures 124 FreeMem 20232
MQTT : Connection lost
MQTT : Connected to broker with client ID: ESPClient_DC:4F:22:80:1D:49
Subscribed to: fg/out
MQTT : Topic: fg/out
MQTT : Payload: Connected
WD : Uptime 1244 ConnectFailures 126 FreeMem 19984
EVENT: Processing time:2388 milliSeconds
EVENT: Processing time:2378 milliSeconds
EVENT: Processing time:2376 milliSeconds
EVENT: Processing time:2379 milliSeconds
EVENT: Inside#=0.00
EVENT: Processing time:2538 milliSeconds
EVENT: Inside#=0.00
EVENT: Processing time:2537 milliSeconds
EVENT: Inside#=0.00
EVENT: Processing time:2533 milliSeconds
EVENT: Clock#Time=Sat,14:09
EVENT: Processing time:2534 milliSeconds
EVENT: SetInsideTemp=41.7
ACT : TaskValueSet 10,1,41.7
EVENT: Processing time:2547 milliSeconds
WD : Uptime 1244 ConnectFailures 125 FreeMem 19984
EVENT: Processing time:2556 milliSeconds
WD : Uptime 1245 ConnectFailures 127 FreeMem 19984
EVENT: Processing time:2385 milliSeconds
EVENT: Processing time:2375 milliSeconds
EVENT: Processing time:2381 milliSeconds
EVENT: Inside#=0.00
EVENT: Processing time:2543 milliSeconds
EVENT: Inside#=0.00
EVENT: Inside#=0.00
EVENT: Processing time:2535 milliSeconds
EVENT: Clock#Time=Sat,14:10
EVENT: Rules#Timer=1
ACT : 0=1
ACT : timerset 1,900
ACT : event,Log=Zone 1 no action - sleep 15 mins
EVENT: Log=Zone 1 no action - sleep 15 mins
ACT : publish FreezeGuard,180217 141016: Zone 1 no action - sleep 15 mins
MQTT : publish failed
EVENT: Processing time:2592 milliSeconds
EVENT: Processing time:5165 milliSeconds
EVENT: Processing time:2560 milliSeconds
WD : Uptime 1245 ConnectFailures 126 FreeMem 19688
EVENT: Processing time:2553 milliSeconds
EVENT: SetOutsideTemp=30.5
ACT : TaskValueSet 9,1,30.5
...etc
on System#Boot do
GPIO,15,0
GPIO,12,0
GPIO,5,0
GPIO,4,0
timerSet 1,60
timerSet 2,300
timerSet 3,540
event,Log=System Startup Complete %ip%
on Rules#Timer=1 do
[Outside#Flag]=1
if [Outside#Temp] > 32
[Outside#Flag]=0
if [Inside#Temp] < 32
event,Log=Inside below freeze point - Force Zone 1 run
[Outside#Flag]=1
if [Outside#Flag]=1
gpio,12,1 // run
timerset 4,300
event,Log=Open Zone 1 for 5 min
timerset 1,900
on Rules#Timer=4 do
gpio,12,0
timerSet 1,3300
event,Log=Close Zone 1 - restart in 55 min
on Rules#Timer=2 do
[Outside#Flag]=1
[Outside#Flag]=0
event,Log=Inside below freeze point - Force Zone 2 run
[Outside#Flag]=1
if [Outside#Flag]=1
gpio,5,1
timerset 5,300
event,Log=Open Zone 2 for 5 min
timerset 2,900
event,Log=Zone 2 no action - sleep 15 mins
on Rules#Timer=5 do
gpio,5,0
timerSet 2,3300
event,Log=Close Zone 2 - restart in 55 min
on Rules#Timer=3 do
[Outside#Flag]=1
[Outside#Flag]=0
event,Log=Inside below freeze point - Force Zone 3 run
[Outside#Flag]=1
if [Outside#Flag]=1
gpio,4,1
timerset 6,300
event,Log=Open Zone 3 for 5 min
timerset 3,900
event,Log=Zone 3 no action - sleep 15 mins
on Rules#Timer=6 do
gpio,4,0
timerSet 3,3300
event,Log=Close Zone 3 - restart in 55 min
on Button1#Press do
if [GPIO12#State] = 0
GPIO,12,1
event,Log=Manual Override Zone 1 Open
GPIO,12,0
event,Log=Manual Override Zone 1 Close
on Button2#Press do
if [GPIO5#State]=0
GPIO,5,1
event,Log=Manual Override Zone 2 Open
GPIO,5,0
event,Log=Manual Override Zone 2 Close
on Button3#Press do
if [GPIO4#State]=0
GPIO,4,1
event,Log=Manual Override Zone 3 Open
GPIO,4,0
event,Log=Manual Override Zone 3 Close
on Log do
publish %sysname%,%sysyears%%sysmonth%%sysday% %syshour%%sysmin%%syssec%: %eventvalue%
on SetOutsideTemp do
TaskValueSet 9,1,%eventvalue%
on SetInsideTemp do
TaskValueSet 10,1,%eventvalue%
Feedback appreciated.
