Barb232
Post
by Barb232 » 11 Apr 2018, 14:02
I have a problem to send the IP from the following example
On System#Boot do //When the ESP boots, do
Publish %sysname%/co2Sensor/IP,%ip%
timerSet,1,30 //Resets the Timer 1 for another 30 seconds
Log
4632 : EVENT: WiFi#ChangedAccesspoint
6338 : WIFI : DHCP IP: 192.168.178.52 (co2Sensor-18) GW: 192.168.178.1 SN: 255.255.255.0 duration: 1707 ms
6338 : EVENT: WiFi#Connected
6438 : MQTT : Intentional reconnect
6824 : MQTT : Connected to broker with client ID: ESPClient_B4:E6:2D:17:FB:AD
6832 : Subscribed to: /co2Sensor/#
6838 : EVENT: MQTT#Connected
15899 : MHZ19: Read error: checksum = 8 / 255 bytes read => 255/255/254/255/255/255/255/255/255/
15901 : MHZ19: Shifted 2 bytes to attempt to fix buffer alignment
31708 : WD : Uptime 1 ConnectFailures 0 FreeMem 16160
61875 : WD : Uptime 1 ConnectFailures 0 FreeMem 16160
76724 : MHZ19: Read error: checksum = 151 / 0 bytes read => 255/255/134/1/154/73/0/0/0/
76725 : MHZ19: Shifted 2 bytes to attempt to fix buffer alignment
91876 : WD : Uptime 2 ConnectFailures 0 FreeMem 16160
121876 : WD : Uptime 2 ConnectFailures 0 FreeMem 16160
136845 : MHZ19: PPM value: 588 Temp/S/U values: 33/0/0.00
136847 : EVENT: co2sensor#PPM=588.00
136856 : EVENT: co2sensor#Temperature=33.00
136863 : EVENT: co2sensor#U=0.00
151876 : WD : Uptime 3 ConnectFailures 0 FreeMem 16144
checkbox rules is enabled
using Release mega-20180410
/robin
wim16
#2
Post
by wim16 » 11 Apr 2018, 14:57
I notice 2 things in your rules, not sure if they cause the problem.
1. You do not set timer1 on boot so the second rule will never fire.
2. Maybe there must be a comma after ' publish' instead of the space.
Barb232
Post
by Barb232 » 11 Apr 2018, 15:43
i think there is a problem with rules
i did this
On co2sensor#PPM >100 do
Gpio,16,1
Endif
and the log says
6707 : MHZ19: PPM value: 410 Temp/S/U values: 32/0/0.00
76709 : EVENT: co2sensor#PPM=410.00
76720 : EVENT: co2sensor#PPM=410.00 Processing time:11 milliSeconds
76721 : EVENT: co2sensor#Temperature=32.00
76730 : EVENT: co2sensor#Temperature=32.00 Processing time:10 milliSeconds
76731 : EVENT: co2sensor#U=0.00
76740 : EVENT: co2sensor#U=0.00 Processing time:9 milliSeconds
76801 : MQTT : /co2Sensor/co2sensor/PPM 410.00
76808 : MQTT : /co2Sensor/co2sensor/Temperature 32.00
76812 : MQTT : /co2Sensor/co2sensor/U 0.00
76814 : MQTT : Topic: /co2Sensor/co2sensor/PPM
76814 : MQTT : Payload: 410.00
76820 : MQTT : Topic: /co2Sensor/co2sensor/Temperature
76820 : MQTT : Payload: 32.00
76821 : MQTT : Topic: /co2Sensor/co2se
so it never runs into the rules
yes, i checked the rules option button...
AndrewJ
#4
Post
by AndrewJ » 11 Apr 2018, 15:47
Barb232 wrote: ↑11 Apr 2018, 15:43
i did this
Gpio,16,1
Endif
and the log says
snipped
Hi, have a look at the Wiki on rules, it will guide you to the answer.
Post again if you are still stuck.
Good luck!
Barb232
Post
by Barb232 » 11 Apr 2018, 16:06
it works now
339563 : EVENT: Rules#Timer=1
339574 : ACT : Publish co2Sensor/co2Sensor/IP,192.168.178.52
339639 : ACT : timerSet,1,30
timerSet,1,30 //Set Timer 1 for the next event in 30 seconds
Solution: I made a factory reset
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
