De-Bounce for reed switch?
TommySharp
#1 Post by TommySharp » 22 Aug 2018, 12:31
I have a reed switch connected and when my garage door closes is see a quick CLOSED, OPENED, CLOSED in quick succession.
Does anyone have any pointers on how I would ignore any updates within 1 second of the first one?
I think the term is a "de bounce"?
Re: De-Bounce for reed switch?
#2 Post by grovkillen » 22 Aug 2018, 13:15
You could use rules for that... on change wait for 1-2 seconds... check again. If the value is still OPEN report open. Etc.
But that might not be a good solution for you? Please report back if you have tried it and it's not working.
TommySharp
#3 Post by TommySharp » 12 Sep 2018, 02:39
Would be great to be able to do this without rules....
Surely this is a common issue with reed switches and a fix could be baked in?
I've never written a rule though so if you could help me with a working example I could give it a try.....
kenkoknz
#4 Post by kenkoknz » 12 Sep 2018, 04:21
Exactly as what @grovkillen said,
I have not tested it but maybe along the lines of (have to press it longer than 1sec, I am not sure if TimerSet works for 0.5):
On ReedSwitch#Open do
TimerSet,1,1
EndOn
On Rules#Timer=1 do
If [ReedSwitch#Open]=0 // 0 or 1 depends on what state you are looking for.
// .....whatever
EndIf
EndOn
Check out great tutorial on rules n give it a go.
Ken
#5 Post by grovkillen » 12 Sep 2018, 06:24
kenkoknz wrote: 12 Sep 2018, 04:21 Exactly as what @grovkillen said,
TimerSet,1,1
EndOn
On Rules#Timer=1 do
// .....whatever
EndIf
EndOn
Ken
Thanks for stepping in! :) I love how the community grow and how we start to take care of each other.
#6 Post by TD-er » 12 Sep 2018, 21:12
When I take on the GPIO issues, one of the things I want to do is to merge functionality of P001_switch and P003_pulsecount.
That last one already has some code to filter de-bounce effects.
TommySharp
#7 Post by TommySharp » 13 Sep 2018, 22:53
I think doing this with a rule is actually a little more complicated than I can manage right now.
Will have to wait till debouncing is built in for reed switches...
