IFs and %syshour% issue
DimOkIdE
#1 Post by DimOkIdE » 13 Oct 2018, 20:02
Hi there.
I'm using the following rule on mega-20180104:
On System#Boot do
	If %systime% < 05:00:00
		GPIO,13,0
		GPIO,14,0
		timerSet,7,240
	Endif
	If %systime% > 05:00:00
		timerSet,7,0
		timerSet,8,0
		timerSet,3,5
		timerSet,4,15
	Endif
	If %systime% > 21:00:00
		GPIO,13,0
		GPIO,14,0
		timerSet,7,240
	Endif
//ON timers
on Rules#Timer=1 do
	GPIO,0,1
on Rules#Timer=2 do
	GPIO,13,1
on Rules#Timer=3 do
	GPIO,12,1
on Rules#Timer=4 do
	GPIO,14,1
//OFF timers
on Rules#Timer=5 do
	GPIO,0,0
on Rules#Timer=6 do
	GPIO,13,0
on Rules#Timer=7 do
	GPIO,12,0
on Rules#Timer=8 do
	GPIO,14,0
and it's working like a charm (turns on/off relays on their pins correctly).
Right now I'd like to update the SW version to the latest (mega-20181011) and trying to use the following rule:
On System#Boot do
	If %syshour% < 05 or %syshour% > 21
		GPIO,13,0
		GPIO,14,0
		timerSet,7,240
		timerSet,7,0
		timerSet,8,0
                timerSet,3,5
		timerSet,4,15
	Endif
//ON timers
on Rules#Timer=1 do
	GPIO,0,1
on Rules#Timer=2 do
	GPIO,13,1
on Rules#Timer=3 do
	GPIO,12,1
on Rules#Timer=4 do
	GPIO,14,1
//OFF timers
on Rules#Timer=5 do
	GPIO,0,0
on Rules#Timer=6 do
	GPIO,13,0
on Rules#Timer=7 do
	GPIO,12,0
on Rules#Timer=8 do
	GPIO,14,0
As I've understood, the %systime% is not working right now (not float) so I've replaced it with the %syshour%. I've also replaced several IFs with logic+else.
But it doesn't works :( The gpios remain 0 no matter what time is it now.
It seems like the problem with the IF inside System#Boot or with %syshour%.
Could anybody help me with this please?
Re: IFs and %syshour% issue
#2 Post by grovkillen » 13 Oct 2018, 20:15
It's not working because the event System#Boot is only happening once.
Try this:
on Clock#Time do
  GPIO,13,0
  GPIO,14,0
  timerSet,7,240
  timerSet,7,0
  timerSet,8,0
  timerSet,3,5
  timerSet,4,15
 Endif
DimOkIdE
#3 Post by DimOkIdE » 13 Oct 2018, 20:56
grovkillen, thanks for a such quick reply!
grovkillen wrote: 13 Oct 2018, 20:15 It's not working because the event System#Boot is only happening once.
Actually, it supposed to fire only once (when the ESP boots) to check the current time and disable/enable gpios depending on the time range.
As I've inderstood - the System#Boot is the right place where to put these conditions?
In the earlier versions of FW it worked. And now it's logic was changed?
If I put the simple IF (without %syshour%) - it works:
On System#Boot do
	GPIO,12,1
	if [Relay4#Switch]=0
		GPIO,13,1
grovkillen wrote: 13 Oct 2018, 20:15 Try this:
on Clock#Time do
It works but it fires every minute:
403333: EVENT: Clock#Time=Sat,21:48
403354: ACT : timerSet,7,0
403368: ACT : timerSet,8,0
403381: ACT : timerSet,3,35
403394: ACT : timerSet,4,55
403454: Command: timerset
403455: Command: timerset
But I need it to fire once on startup. And then I have several rules on dummy buttons.
#4 Post by grovkillen » 13 Oct 2018, 21:07
Then you should use the Time#Initialized event.
https://www.letscontrolit.com/wiki/inde ... .29_events
We have made the boot sequence more stable and now the boot event is triggered on actual boot. Thus we needed a time initialized event.
DimOkIdE
#5 Post by DimOkIdE » 13 Oct 2018, 21:22
Oh, intersting.
Trying:
On Time#Initialized do
	If %syshour% > 12 and %syshour% < 23
		timerSet,7,0
		timerSet,8,0
		timerSet,3,85
		timerSet,4,95
	Endif
Doesn't work.
Found the similar topic here (http://www.letscontrolit.com/forum/view ... zed#p31376). Modified to:
	event checkRelays
on checkRelays do
		timerSet,7,0
		timerSet,8,0
		timerSet,3,85
		timerSet,4,95
	Endif
And it really works :)
grovkillen, thank you greatly! I think this will be enough for me on this stage because it really fires only once.
#6 Post by grovkillen » 13 Oct 2018, 22:31
Your first example might actually happen before the %syshour% is populated. Maybe we should add a issue for that?
#7 Post by TD-er » 13 Oct 2018, 23:10
It should be fixed with this pull request: https://github.com/letscontrolit/ESPEasy/pull/1900
I will merge it as soon as possible.
