PN532 and Home Assistant
mufidsyed
#1 Post by mufidsyed » 23 Oct 2018, 06:21
I have a nodemcu running the Release mega-20181022 stable version along with a PN532. I am able to read the tags. I have also integrated the same into my home assistant.
While setting up automation i found that home assistant does not realize the same tag being read multiple times. In order to avoid the same is there anyway i can use rules to reset the readings of the PN532 after 3 seconds of every read. i.e. once the card is detected, after 3 seconds, the value should be something other than what was read.
Thank you
Re: PN532 and Home Assistant
#2 Post by grovkillen » 23 Oct 2018, 06:30
Are the tag numbers integers or is there letters inside them? If they are numbers only (=integers) then you can store them inside the newly added internal variables (1...16) or use traditional dummy devices.
mufidsyed
#3 Post by mufidsyed » 23 Oct 2018, 06:42
tag numbers are all intergers. sorry this is very new to me. can you tell me where can i find the internal variable or traditional dummy devices
#4 Post by grovkillen » 23 Oct 2018, 06:48
If you look in the wiki regarding rules you get a good start. After that you can come here and I'll help you out.
#5 Post by grovkillen » 23 Oct 2018, 06:49
mufidsyed
#6 Post by mufidsyed » 23 Oct 2018, 09:40
so going through the rules this is what i came up with. the rfid is connected to i2c whichi would be GPIO-4 for SDA and GPIO-5 for SCL
On Rules#Timer=1 do
if[esp004#tag]>0
gpio,4,%value%
gpio,4,000000000
timerSet,1,3
is this correct
#7 Post by grovkillen » 23 Oct 2018, 10:24
No you need to create either a dummy device or use the newly added system variables. So either you do it like this:
Old way with dummy devices (I place them on task number 12 in this example, naming them Dummy#CurrentTag and Dummy#ZeroTag), if your esp004#tag device is on task number 1 and value number 1 this would then hopefully work.
On System#Boot Do
 taskValueSet,12,2,123456789
EndOn
On esp004#tag Do
 taskValueSet,12,1,[esp004#tag] //Setting dummy vaue 1 to the tag code
 TimerSet,1,3
EndOn
On Rules#Timer=1 Do
 If [esp004#tag] = [Dummy#CurrentTag] //If the tag code is still the same after 3 seconds clear it
   taskValueSet,1,1,[Dummy#ZeroTag]
  EndIf
EndOn
New way would be to use this:
On System#Boot Do
 Let,1,123456789
EndOn
On esp004#tag Do
 Let,2,[esp004#tag]
 TimerSet,1,3
EndOn
On Rules#Timer=1 Do
 If [esp004#tag] = %v2%
   taskValueSet,1,1,%v1%
  EndIf
EndOn
I'm typing this out of my head so please get back here if something is not working as you was hoping.
Domosapiens
#8 Post by Domosapiens » 24 Oct 2018, 09:17
Let,1,123456789
Let statement?
Can you enlighten us about this new way?
#9 Post by grovkillen » 24 Oct 2018, 12:17
It's only a couple of days old. I will add more info about it but in short:
Let,<value number 1...16>,<float>
Example
Let,1,10
Let,2,20
Publish,Answer/%v1%+%v2,(%v1%+%v2%)
This would render in this being published
Topic
Answer/10+20
Domosapiens
#10 Post by Domosapiens » 24 Oct 2018, 22:52
Ohhh great :idea:
