Build custom ESP8685_1M with C005, P001, P033 ... with vscode & platformio
JR01
#1 Post by JR01 » 27 Oct 2020, 21:31
Hi all clever peeps !
I want to build a custom, small image for ESP8266 "Sonoff IoT WiFi Development Board" with only:
1) CONTROLLERS - "Home Assistant (openHAB) MQTT" (is this still the right mqtt Controller for generic MQTT?)
2) PLUGINS: a) Switch, b) "Generic - System Info", c) "Generic - Dummy"
I want to do it on vscode, according to https://espeasy.readthedocs.io/en/lates ... th-vs-code ...
I need to edit
../source/tools/pio/pre_custom_esp82xx.py
to add (whilst commenting other plugins & controllers out):
# "CONTROLLER_SET_ALL",
"USES_C005", # Openhab MQTT
"USES_P001", # Switch
"USES_P033", # Dummy
..Then go to platformio icon, then to Project Tasks env:custom:ESP8266_1M > Build.
Does this sound about right to only build with the controllers & plug-ins I want?
Re: Build custom ESP8685_1M with C005, P001, P033 ... with vscode & platformio
#2 Post by ThomasB » 28 Oct 2020, 02:29
Yes, your general workflow sounds legit.
BTW, "USES_P026" is needed to add the System Info plugin.
#3 Post by TD-er » 28 Oct 2020, 09:32
Maybe also set the PLUGIN_SET_NONE to make sure it doesn't enable PLUGIN_SET_STABLE by default.
JR01
#4 Post by JR01 » 28 Oct 2020, 15:10
Thank you all.
Users browsing this forum: Bing [Bot] and 2 guests
