in the source i see the following line:
addLog(LOG_LEVEL_INFO, F("SGP30: Restore last known baseline values"));
When will the baseline stored ?
regards Klaus
SGP30 Datasheet:I'm not sure if the SGP30 needs any external compensation, but I think it has that capability/compensation itself.
In my understanding, TESTING builds are builds to test.According to the list of plugins this plugin is in the TESTING A build-set, so it is available for use.
As i mentioned before:"Testing" is a legacy naming schema which we need to change as it is confusing.
I'm open for suggestions for a better name.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
