I use many brands of temperature sensors here (they have just grown with time =)), and in general they work quite well with rflink.
Well, some do more than others.
They update about once a minute, of course sometimes there can go something wrong (maybe some bird in the wrong position ), so it might take the second attempt, but that I would still call reliable.
This holds for
- Firstline
- LaCrosse
- Oregon_TempHygro,
but not for
- Baldr
- InoValley_SM200
- F007_TH
- Xiron
(for the latter you see an example in the "code" below).
I really wonder, what's going wrong, and if there maybe something could be tweaked in rflink to fix this.
Would be great.
Greets
javascript.0 2022-12-09 13:27:52.037 warn (10995) script.js.common.Wachtür: *** TK:-19.8 (30 Min.) ***
javascript.0 2022-12-09 12:57:28.211 warn (10995) script.js.common.Wachtür: *** TK:-13.3 (10 Min.) ***
javascript.0 2022-12-09 12:47:01.063 warn (10995) script.js.common.Wachtür: *** TK:-14.4 (13 Min.) ***
javascript.0 2022-12-09 12:33:43.098 warn (10995) script.js.common.Wachtür: *** TK:-16.1 (1 Min.) ***
javascript.0 2022-12-09 12:31:49.089 warn (10995) script.js.common.Wachtür: *** TK:-16.4 (18 Min.) ***
javascript.0 2022-12-09 12:12:49.110 warn (10995) script.js.common.Wachtür: *** TK:-19.3 (15 Min.) ***
javascript.0 2022-12-09 11:57:37.115 warn (10995) script.js.common.Wachtür: *** TK:-17.4 (2 Min.) ***
javascript.0 2022-12-09 11:54:46.127 warn (10995) script.js.common.Wachtür: *** TK:-16.4 (1 Min.) ***
javascript.0 2022-12-09 11:52:52.127 warn (10995) script.js.common.Wachtür: *** TK:-15.6 (0 Min.) ***
javascript.0 2022-12-09 11:51:55.118 warn (10995) script.js.common.Wachtür: *** TK:-15.4 (8 Min.) ***
javascript.0 2022-12-09 11:43:22.149 warn (10995) script.js.common.Wachtür: *** TK:-13 (1 Min.) ***
javascript.0 2022-12-09 11:41:28.141 warn (10995) script.js.common.Wachtür: *** TK:-13.2 (8 Min.) ***
javascript.0 2022-12-09 11:32:55.150 warn (10995) script.js.common.Wachtür: *** TK:-13.9 (0 Min.) ***
javascript.0 2022-12-09 11:31:58.152 warn (10995) script.js.common.Wachtür: *** TK:-14 (3 Min.) ***
javascript.0 2022-12-09 11:28:10.141 warn (10995) script.js.common.Wachtür: *** TK:-14.4 (3 Min.) ***
javascript.0 2022-12-09 11:24:22.173 warn (10995) script.js.common.Wachtür: *** TK:-14.7 (11 Min.) ***
javascript.0 2022-12-09 11:12:58.185 warn (10995) script.js.common.Wachtür: *** TK:-16.3 (21 Min.) ***
javascript.0 2022-12-09 10:51:07.201 warn (10995) script.js.common.Wachtür: *** TK:-19.4 (14 Min.) ***
javascript.0 2022-12-09 10:36:52.229 warn (10995) script.js.common.Wachtür: *** TK:-16.5 (19 Min.) ***
javascript.0 2022-12-09 10:16:55.247 warn (10995) script.js.common.Wachtür: *** TK:-13.4 (5 Min.) ***
javascript.0 2022-12-09 10:11:13.231 warn (10995) script.js.common.Wachtür: *** TK:-13.9 (5 Min.) ***
javascript.0 2022-12-09 10:05:31.246 warn (10995) script.js.common.Wachtür: *** TK:-15.3 (4 Min.) ***
javascript.0 2022-12-09 10:00:46.237 warn (10995) script.js.common.Wachtür: *** TK:-15.9 (32 Min.) ***
javascript.0 2022-12-09 09:28:28.283 warn (10995) script.js.common.Wachtür: *** TK:-17.8 (3 Min.) ***
javascript.0 2022-12-09 09:24:40.277 warn (10995) script.js.common.Wachtür: *** TK:-17.6 (0 Min.) ***
javascript.0 2022-12-09 09:23:43.269 warn (10995) script.js.common.Wachtür: *** TK:-17.4 (1 Min.) ***
javascript.0 2022-12-09 09:21:49.281 warn (10995) script.js.common.Wachtür: *** TK:-16.9 (2 Min.) ***
javascript.0 2022-12-09 09:18:58.278 warn (10995) script.js.common.Wachtür: *** TK:-15.6 (1 Min.) ***
javascript.0 2022-12-09 09:17:04.297 warn (10995) script.js.common.Wachtür: *** TK:-14.5 (13 Min.) ***
javascript.0 2022-12-09 09:03:46.298 warn (10995) script.js.common.Wachtür: *** TK:-14 (18 Min.) ***
javascript.0 2022-12-09 08:45:43.324 warn (10995) script.js.common.Wachtür: *** TK:-16.4 (1 Min.) ***
javascript.0 2022-12-09 08:43:49.317 warn (10995) script.js.common.Wachtür: *** TK:-16.8 (5 Min.) ***
javascript.0 2022-12-09 08:38:07.312 warn (10995) script.js.common.Wachtür: *** TK:-17.5 (2 Min.) ***
javascript.0 2022-12-09 08:35:16.313 warn (10995) script.js.common.Wachtür: *** TK:-18.4 (10 Min.) ***
javascript.0 2022-12-09 08:24:49.350 warn (10995) script.js.common.Wachtür: *** TK:-19.5 (55 Min.) ***
