DTH22 Freeze from 8 to 14h of run
seb42fr
#1 Post by seb42fr » 31 Dec 2022, 14:31
I have buy 3 DHT22 ESP8266 module.
Capture d’écran du 2022-12-31 14-30-31.png (139.57 KiB) Viewed 1307 times
I have same problems on these modules.
After many hours of run, the value of DHT22 probe read by ESP is freeze. I have make some test, but nothing work :
- Disable the Serial port in Tools/Advanced
- Decrease the I2C speed
- The reboot the ESP with Web interface is not unlocking it
- The hard reset of ESP8266 is not unlocking it
- The unplug and plug the ESP of header block is not unlocking it
I must make a power-off and a power-on of the module and the measurement come back ... for some hours
Any Idea ?
The device page:
Capture d’écran du 2022-12-31 14-15-21.png (72.83 KiB) Viewed 1307 times
The domoticz measurement of three equipment who was started at same time:
Capture d’écran du 2022-12-31 14-27-21.png (47.76 KiB) Viewed 1307 times
Capture d’écran du 2022-12-31 14-23-21.png (52.91 KiB) Viewed 1307 times
Capture d’écran du 2022-12-31 14-26-28.png (52.6 KiB) Viewed 1307 times
Thank you
Seb
Re: DTH22 Freeze from 8 to 14h of run
#2 Post by Ath » 31 Dec 2022, 16:45
What exact .bin file do you have installed on the ESP?
Bert'Ridder
#3 Post by Bert'Ridder » 31 Dec 2022, 18:50
These ESP-shields do I als use, but a few of them have the same issue.
t is in my case a hardware-problem of the Powersupply-chip on the board.
Please check, with an ".bin" that has the VCC on it and then check the system-variable %vcc%.
In my cases the result was that the VCC as about 3,6 V. The 8266 can only accept about max 3.5 V and then after some time working with an too high Voltage the 8266 freeses.
Also try to extend the Task - Interval from 2 seconds to at least 10 or even 30 Seconds. This also can freese the DHT22
#4 Post by TD-er » 01 Jan 2023, 01:41
DHTxx sensors tend to do this.
The DHT11 even more than the DHT22.
Just google on them.
For example the first hit when searching for "DHT22 freeze": https://discourse.nodered.org/t/dht22-f ... on/20174/2
