Sonoff 4CH R3 GPIO
DomoticaRob
Sonoff 4CH R3 GPIO
#1 Post by DomoticaRob » 06 Nov 2023, 22:11
I have bought a couple of Sonoff 4CH R3 switches.
Sonoff 4CH R3.jpg (13.78 KiB) Viewed 4167 times
Sonoff 4CH R3 Print.jpg (394.02 KiB) Viewed 4167 times
I have flashed ESPEasy and now I want to make it suitable for mij Domoticz system.
Google tells me the folowing GPIO declarations:
Button 1 = GPIO 0
Button 2 = GPIO 9
Button 3 = GPIO 10
Button 4 = GPIO 14
Relay 1 = GPIO 12
Relay 2 = GPIO 5
Relay 3 = GPIO 4
Relay 4 = GPIO 15
In ESPEasy I get by devices the folowing GPIO possibilities:
Soort device.jpg (107.36 KiB) Viewed 4167 times
That is totally different then what Sonoff wants
How can I use this Sonoff 4 channel relay box with ESPEasy?
chromo23
Re: Sonoff 4CH R3 GPIO
#2 Post by chromo23 » 06 Nov 2023, 22:16
Disable I2C by setting the GPIOs to "none".
After that you can choose the missing GPIOs
#3 Post by TD-er » 06 Nov 2023, 22:16
The greyed out options are now set to some other feature, like I2C.
On the Hardware tab, you can set the SDA/SCL pins for I2C to "not set" and then they are available to select in your select options.
The same for the "ESPEasy console" on the Tools->Advanced page.
If you uncheck that option, you can pick GPIO 1 and 3.
DomoticaRob
#4 Post by DomoticaRob » 06 Nov 2023, 22:46
Thanks for the very very fast respons.
The relays are working.
Super, super, super.
One 'but' left.
I also want to use the buttons of the Sonoff.
Button 1 = GPIO 0
Button 2 = GPIO 9
Button 3 = GPIO 10
Button 4 = GPIO 14
Button 1, 3,and 4 are directed to the proper GPIO's
Button 2 wants to be directed to GPIO 9 and GPIO 9 is not in the list of ESPEasy.
How can I use button 2?
#5 Post by TD-er » 06 Nov 2023, 22:59
You can add several switch input tasks.
Each with their own set GPIO and name the tasks with their own unique task name. (e.g. "Button1" ... "Button4")
Then in the rules you can simply act on the events when a button is pressed.
Example rule to couple "button1" to GPIO-12:
on Button1#switch do
  gpio,12,%eventvalue1%
Just make sure to set the Switch task to "Push Button Active Low" and set the debounce to something like 100 msec.
#6 Post by Ath » 06 Nov 2023, 23:03
As GPIO is missing from the list, you can set up a monitor for that pin:
on System#Boot do
  monitor,GPIO,9
on GPIO#9 do
  // Act for Button 2, %eventvalue1% is holding the state 0/1
To start the monitor without a reboot, you can type that "monitor,gpio,9" command (it's not case-sensitive) on the Tools page to activate it immediately.
#7 Post by Ath » 06 Nov 2023, 23:13
What build of ESPEasy do you have installed? (name of the .bin file please) as most likely the ESP on board is an ESP8285, that should have GPIO 9 available for use, but only a somewhat recent build (max 1 year old) has the auto-detect feature for ESP8266 vs ESP8285, enabling the few extra pins. You can see the detected ESP on the System Info page.
#8 Post by TD-er » 06 Nov 2023, 23:23
And also the actual size of the flash memory.
There should exist some ESP8285 with 2MB flash and according to some model nr I found in the documentation there might even exist a 4M version of the ESP8285.
If you happen to have one with 2MB or more flash memory, then you could also use a build for 2M flash which makes updating to a newer build a lot simpler.
#9 Post by Ath » 07 Nov 2023, 13:09
TD-er has deployed a new build on https://td-er.nl/ESPEasy/latest/ that has a fix to allow selection of GPIO 9 on an ESP8285 unit like this Sonoff 4CH R3 seems to be.
You can install and test that when using Chrome or Edge browsers and the unit is connected to your USB Serial connection ( !!! DON'T connect the unit to mains power when also connecting to USB Serial !!! )
Feedback is welcome ;)
DomoticaRob
#10 Post by DomoticaRob » 08 Nov 2023, 19:06
I am out for a few days.
After the weekend I wil try the rules thing and the TD binarie.
DomoticaRob
#11 Post by DomoticaRob » 08 Nov 2023, 20:43
I had a few minutes extra so I flashed with th TD binarie:
ESP_Easy_mega_20231107_normal_ESP8266_1M
And it works, super.
The only small disadvantage is yhat after a reboot relay 1 and relay 2 are activated.
After pressing the buttons the are de-activated.
I have changed the 'Send Boot State' and also the 'Internal Pull Up' and also the 'Inversed Logic'.
I will look further into it to find out what is the solution.
TD,
Thanks for this binarie, super.
#12 Post by TD-er » 08 Nov 2023, 21:25
Do you also use some external service/server like Domoticz or HomeAssistant or anything like those?
In other words, do you need to keep the relay state in sync with some external service?
DomoticaRob
#13 Post by DomoticaRob » 08 Nov 2023, 22:03
Yes, I use Domoticz.
I was a little too enthousiastic.
When I again pluged in the module it was not reachenable.
I will find out later what is the problem.
#14 Post by TD-er » 08 Nov 2023, 22:20
Please also have a look at this one:
https://espeasy.readthedocs.io/en/lates ... #p029-page
When you need to keep a relay/switch in sync with Domoticz, you need to take care to not end up with lots of on/off/on/off flipping of the relay when you boot ESPEasy while Domoticz assumes a different state.
Users browsing this forum: Ahrefs [Bot] and 2 guests
