What does the field "Sensor Delay" stand for in the config tab?
I thought the interval period of a new sensor value to be taken?
But I suppose if you use a pulse counter it is ignored?
config: sensor delay
Re: config: sensor delay
That's correct.Mediacj wrote:What does the field "Sensor Delay" stand for in the config tab?
Pulses are counted in background using interrupts. But after the configured delay, the delta count is send to the HA controller and the count is reset.Mediacj wrote:But I suppose if you use a pulse counter it is ignored?
Ok clear thx
To be sure the "sensor delay" is in seconds where "message delay" is in ms?
