I am trying to integrate my 3 Estares (Chinese, Maysun manufacturer) lights into Domoticz\RFLink.
To start with: Gravitacia 80W lamp
The picture of remote is attached.
I have tried to capture the remote in debug mode of RFLink, pressing each button twice.
To be noted, remote control has syncing functionality which is not captured. e.g. when you turn off mains completely, keep the channel button pressed on the remote and turn on the mains, remote gets linked to light.
Is it possible to support it in RFLink?
Aram
P.S.
I do have some background "radio noise" of devices from my neighbours in 433mhz, which might have been captured in debug log.
Maysun \ Estares Gravitacia LED Lamp
- lightcode_gravitacia.xlsx.zip
- (9.19 KiB) Downloaded 307 times
- maysun_grav_remote.jpg (53.28 KiB) Viewed 4261 times
Re: Maysun \ Estares Gravitacia LED Lamp
Found out Domoticz identifies the remote button while in "Learning" mode as SelectPlus3 protocol
However if you press the button it gives an error in the log
Is there any kind of tutorial one could use to add the support or help with the process?
Turn OFF
(uSec)=30,390,3960,1110,60,300,60,330,30,330,60,300,330,30,60,300,330,30,330,30,60,330,60,300,330,30,60,300,60,330,30,330,60,330,30,330,60,300,60,330,330,30,60,330,60,300,60,330,60,300,330,30,60,330;
20;04;DEBUG;Pulses=52;Pulses(uSec)=90,1560,30,300,30,300,30,300,30,300,300,30,30,300,300,30,300,30,30,300,30,330,330,30,60,330,60,300,60,330,30,330,60,330,30,330,60,300,330,30,60,300,60,330,30,300,60,330,330,30,60,330;
20;05;DEBUG;Pulses=52;Pulses(uSec)=90,1560,30,300,30,300,30,300,30,300,300,30,30,300,330,30,330,30,60,330,30,300,330,30,60,300,60,330,60,300,60,330,30,330,60,300,60,330,330,30,60,330,60,300,60,330,60,300,330,30,60,330;
20;06;DEBUG;Pulses=52;Pulses(uSec)=90,1560,30,300,30,300,30,300,30,300,300,30,30,300,330,30,330,30,60,300,60,330,330,30,60,330,60,300,60,330,30,330,60,330,30,330,60,300,330,30,60,300,60,330,60,300,60,330,330,30,60,330;
20;07;DEBUG;Pulses=52;Pulses(uSec)=150,1500,60,300,30,300,30,300,30,300,300,30,30,300,330,30,330,30,60,330,60,300,330,30,60,300,60,330,60,300,60,330,30,330,60,300,60,330,330,30,60,330,60,300,60,330,60,300,330,30,60,330;
20;08;DEBUG;Pulses=176;Pulses(uSec)=120,300,30,300,30,300,30,300,30,300,300,30,300,30,30,300,30,300,30,300,60,270,30,300,30,2220,60,330,60,300,60,330,30,330,330,30,30,330,330,30,330,30,60,300,30,330,330,30,60,330,60,300,60,330,60,300,60,330,30,330,330,30,330,30,60,300,60,330,60,300,60,330,60,300,60,2340,60,300,60,330,60,300,60,330,330,30,60,330,330,30,330,30,60,330,60,300,330,30,60,300,60,330,60,300,60,330,30,330,60,330,330,30,330,30,60,330,60,300,60,330,60,300,60,330,60,2310,60,330,60,300,60,330,30,330,330,30,30,330,330,30,330,30,60,300,60,330,330,30,60,330,60,300,60,330,60,300,60,330,30,330,330,30,330,30,60,300,60,330,60,300,60,330,30,300,60,6990;
20;09;DEBUG;Pulses=280;Pulses(uSec)=960,900,870,870,870,900,870,870,870,900,870,870,870,870,870,900,870,870,870,870,870,870,870,870,870,870,870,870,870,870,870,390,390,870,390,390,870,390,390,870,390,390,870,900,870,390,390,870,390,390,870,390,390,900,390,390,870,390,390,900,390,390,870,870,870,870,870,390,390,900,390,390,870,390,390,870,390,390,870,870,870,390,390,870,870,900,390,390,870,390,390,900,870,870,870,870,390,390,870,390,390,870,390,390,870,870,870,390,390,870,390,390,870,870,870,870,870,390,390,870,390,390,870,390,390,900,870,870,870,870,390,390,870,390,390,870,900,870,870,870,870,870,870,870,870,900,870,900,390,390,870,390,390,900,870,870,870,870,870,900,870,870,870,870,390,390,870,390,390,870,390,390,870,390,390,900,870,900,870,870,390,390,870,390,390,870,870,900,870,870,390,390,870,390,390,900,870,870,390,390,870,390,390,870,870,870,870,870,870,870,390,390,870,900,870,390,390,870,870,870,870,870,870,870,390,390,870,900,870,390,390,870,870,870,870,870,390,390,870,390,390,900,390,390,870,870,870,390,390,870,390,390,870,390,390,900,390,390,870,390,390,900,870,870,390,390,870,390,390,900,390,390,870,390,390,870,390,390,870,6990;
20;0B;DEBUG;Pulses=54;Pulses(uSec)=60,360,3960,1110,60,300,60,330,60,300,60,330,330,30,60,330,330,30,330,30,30,330,60,330,330,30,60,300,60,330,60,300,60,330,60,300,330,30,60,300,330,30,60,300,60,330,30,330,60,300,330,30,60,330;
20;0C;DEBUG;Pulses=49;Pulses(uSec)=90,1560,30,300,30,300,30,300,30,300,300,30,30,300,300,30,300,30,30,300,30,330,330,30,30,330,60,300,60,330,60,300,60,330,330,30,60,330,330,30,60,330,30,330,60,330,30,330,330;
20;0D;DEBUG;Pulses=24;Pulses(uSec)=120,300,30,300,60,300,300,30,30,300,300,30,60,300,30,300,30,300,30,300,300,30,30,300;
20;0E;DEBUG;Pulses=52;Pulses(uSec)=120,1560,30,300,30,300,30,300,30,300,300,30,30,300,300,30,300,30,30,300,30,300,300,30,60,330,60,300,60,330,60,300,60,330,330,30,60,330,330,30,60,330,30,330,60,330,30,330,330,30,60,330;
20;0F;DEBUG;Pulses=52;Pulses(uSec)=90,1560,30,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,30,330,60,330,330,30,60,300,60,330,60,300,60,330,60,300,330,30,60,300,330,30,60,300,60,330,30,330,30,330,330,30,60,330;
20;10;DEBUG;Pulses=204;Pulses(uSec)=150,330,3780,1080,30,330,60,300,60,330,30,300,330,30,60,300,330,30,330,30,60,330,30,330,330,30,30,330,60,300,60,330,60,300,60,330,330,30,330,30,330,30,60,330,60,300,60,330,30,330,60,330,30,2310,60,300,60,330,60,300,60,330,330,30,60,330,330,30,330,30,60,300,60,330,330,30,60,330,30,330,60,300,60,330,60,300,330,30,330,30,330,30,60,300,60,330,30,330,60,330,30,300,60,2310,30,330,60,300,60,330,60,300,330,30,60,300,330,30,330,30,60,330,30,330,330,30,30,330,60,300,60,330,60,300,60,330,330,30,330,30,330,30,60,330,60,300,60,330,30,330,30,330,30,2340,60,300,60,330,60,300,60,330,330,30,60,330,330,30,330,30,60,300,60,330,330,30,60,330,30,330,60,300,60,330,60,300,330,30,330,30,330,30,60,300,60,330,30,330,60,330,30,330,60,6990;
Turn ON
20;11;DEBUG;Pulses=54;Pulses(uSec)=30,450,3960,1110,60,300,60,330,30,300,60,330,330,30,60,330,330,30,330,30,30,330,30,300,330,30,60,300,60,330,60,300,60,330,60,300,60,330,60,300,330,30,30,330,60,330,330,30,60,300,330,30,60,330;
20;12;DEBUG;Pulses=52;Pulses(uSec)=90,1500,30,300,30,300,60,300,30,300,300,30,30,300,300,30,300,30,30,300,30,330,330,30,60,330,30,300,60,330,60,300,30,330,60,300,30,330,330,30,60,330,30,330,330,30,60,330,330,30,60,330;
20;13;DEBUG;Pulses=52;Pulses(uSec)=90,1500,30,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,30,330,60,300,330,30,60,300,60,330,60,300,60,330,30,300,60,330,30,300,330,30,30,330,30,330,330,30,60,300,330,30,60,330;
20;14;DEBUG;Pulses=52;Pulses(uSec)=150,1500,30,300,30,300,30,300,30,300,300,30,30,300,330,30,330,30,60,330,30,330,330,30,60,330,30,300,60,330,60,300,60,330,30,300,30,330,330,30,60,330,30,330,330,30,30,330,330,30,60,330;
20;15;DEBUG;Pulses=176;Pulses(uSec)=120,300,30,300,30,300,60,300,30,300,300,30,300,30,60,300,30,300,30,300,30,300,30,300,30,2220,60,300,60,330,60,300,30,330,330,30,60,330,330,30,330,30,30,330,60,330,330,30,60,300,60,330,60,300,60,330,60,300,30,330,330,30,330,30,60,300,60,330,30,330,60,330,30,330,60,2310,60,330,30,300,60,330,60,300,330,30,60,300,330,30,330,30,60,330,30,330,330,30,30,330,60,300,30,330,60,300,30,330,60,300,330,30,330,30,60,330,30,300,60,330,30,330,60,300,60,2340,60,300,60,330,60,300,60,330,330,30,60,330,330,30,330,30,30,330,60,330,330,30,60,300,60,330,60,300,60,330,30,300,60,330,330,30,330,30,60,300,60,330,30,330,30,330,30,330,60,6990;
20;16;DEBUG;Pulses=54;Pulses(uSec)=120,390,3960,1110,60,330,30,330,60,300,60,330,330,30,60,330,330,30,330,30,60,300,60,330,330,30,60,330,30,330,60,330,30,330,30,300,330,30,60,300,330,30,60,300,30,330,330,30,60,330,330,30,60,360;
20;17;DEBUG;Pulses=52;Pulses(uSec)=120,1500,30,300,30,300,30,300,30,300,300,30,30,300,300,30,300,30,30,300,30,300,330,30,60,300,60,330,30,330,60,300,60,330,330,30,60,330,330,30,60,330,30,300,330,30,60,300,330,30,30,330;
20;18;DEBUG;Pulses=52;Pulses(uSec)=120,1500,30,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,300,30,330,330,30,60,330,30,330,60,330,30,330,30,300,330,30,60,300,330,30,60,300,30,330,330,30,60,330,330,30,60,330;
20;19;DEBUG;Pulses=52;Pulses(uSec)=150,1500,30,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,330,60,300,330,30,60,300,60,330,30,330,30,330,30,330,330,30,60,330,330,30,60,330,30,300,330,30,60,300,330,30,30,330;
20;1A;DEBUG;Pulses=126;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,300,30,300,30,30,300,30,300,30,300,30,300,30,300,30,2220,60,330,30,330,30,330,30,330,330,30,60,330,330,30,330,30,60,300,30,330,330,30,60,330,30,300,60,330,30,330,60,300,330,30,330,30,330,30,60,300,60,330,60,300,30,330,60,300,60,2340,60,300,60,330,30,330,60,300,330,30,60,300,330,30,330,30,60,330,60,300,330,30,60,300,60,330,30,330,60,330,30,330,330,30,330,30,330,30,60,330,60,300,60,330,30,300,30,330,60,6990;
Default Light Settings (e.g. neutral temperature, max brightness)
20;1D;DEBUG;Pulses=54;Pulses(uSec)=30,240,3960,1110,60,300,60,330,60,300,60,330,330,30,60,330,330,30,330,30,60,300,60,330,330,30,60,300,60,330,30,300,60,330,60,300,60,330,60,330,330,30,60,300,60,330,330,30,330,30,330,30,60,330;
20;1E;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,60,300,300,30,30,300,300,30,300,30,30,300,30,330,330,30,30,330,30,300,60,330,60,300,60,330,60,300,60,330,330,30,60,330,60,300,330,30,330,30,330,30,30,330;
20;1F;Doorbell;ID=5901;SWITCH=1;CMD=ON;CHIME=01;
20;20;DEBUG;Pulses=54;Pulses(uSec)=60,240,3930,1110,60,300,60,330,60,300,60,330,330,30,60,330,330,30,330,30,30,330,30,300,330,30,60,300,60,330,60,300,60,330,60,300,330,30,60,300,330,30,30,330,60,330,330,30,330,30,330,30,60,330;
20;21;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,60,270,300,30,30,300,300,30,300,30,30,300,30,330,330,30,60,330,60,300,30,330,60,300,60,330,330,30,60,330,330,30,60,330,30,330,330,30,330,30,330,30,60,330;
20;22;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,60,330,330,30,330,30,30,330,30,330,330,30,60,300,60,330,60,300,30,330,60,300,330,30,60,300,330,30,30,330,60,330,330,30,330,30,330,30,60,330;
20;23;Doorbell;ID=5905;SWITCH=1;CMD=ON;CHIME=01;
20;24;DEBUG;Pulses=52;Pulses(uSec)=3630,1140,30,330,30,330,30,330,60,300,330,30,60,300,330,30,330,30,60,330,60,300,330,30,60,300,60,330,30,330,60,330,30,330,30,300,30,330,330,30,60,330,60,300,330,30,330,30,330,30,60,330;
20;25;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,300,60,330,330,30,60,330,60,300,60,330,30,330,60,330,30,330,60,300,330,30,60,300,60,330,330,30,330,30,330,30,60,330;
20;26;Doorbell;ID=5901;SWITCH=1;CMD=ON;CHIME=01;
Increase brighntess
20;27;DEBUG;Pulses=54;Pulses(uSec)=60,240,3960,1110,60,330,30,330,60,300,60,330,330,30,60,330,330,30,330,30,60,300,60,330,330,30,60,330,30,330,30,330,30,330,60,300,330,30,60,300,330,30,60,300,330,30,60,300,30,330,330,30,60,360;
20;28;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,30,300,300,30,300,30,30,300,30,300,330,30,60,300,60,330,30,330,60,330,30,330,330,30,60,330,330,30,60,330,330,30,60,330,30,300,330,30,60,330;
20;29;Doorbell;ID=5905;SWITCH=1;CMD=ON;CHIME=01;
20;2A;DEBUG;Pulses=54;Pulses(uSec)=30,240,3960,1110,60,330,30,330,30,330,30,330,330,30,60,330,330,30,330,30,60,300,60,330,330,30,60,330,30,330,60,330,30,330,60,300,60,330,60,300,330,30,60,300,330,30,60,300,60,330,330,30,60,360;
20;2B;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,30,300,300,30,300,30,30,300,30,300,330,30,60,300,60,330,60,300,60,330,30,330,60,300,30,330,330,30,60,330,330,30,60,330,60,300,330,30,60,330;
20;2C;Doorbell;ID=5901;SWITCH=1;CMD=ON;CHIME=01;
Dim brightness
20;39;DEBUG;Pulses=54;Pulses(uSec)=90,360,3930,1110,60,300,30,330,60,300,60,330,330,30,60,330,330,30,330,30,30,330,30,300,330,30,60,300,60,330,60,300,60,330,30,300,330,30,60,300,330,30,30,330,330,30,30,330,330,30,60,300,60,330;
20;3A;DEBUG;Pulses=52;Pulses(uSec)=150,1500,30,300,30,300,60,300,30,300,300,30,30,270,300,30,300,30,30,300,30,330,330,30,60,330,60,300,60,330,60,300,30,330,330,30,60,330,330,30,60,330,330,30,60,300,330,30,60,300,60,330;
20;3B;DEBUG;Pulses=52;Pulses(uSec)=150,1500,30,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,30,330,60,300,330,30,60,300,60,330,60,300,30,330,60,300,330,30,60,300,330,30,30,330,330,30,30,330,330,30,60,300,60,330;
20;3C;DEBUG;Pulses=176;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,300,30,300,30,60,300,30,300,30,300,30,270,60,300,30,2220,60,330,60,300,60,330,60,300,330,30,60,300,330,30,330,30,60,330,30,330,330,30,60,330,60,300,60,330,60,300,60,330,330,30,330,30,330,30,60,330,30,330,60,330,30,330,60,300,60,2340,60,300,60,330,60,300,60,330,330,30,60,330,330,30,330,30,30,330,60,330,330,30,60,300,60,330,60,300,30,330,60,300,330,30,330,30,330,30,60,300,60,330,30,330,60,330,30,300,60,2310,60,330,60,300,60,330,60,300,330,30,60,300,330,30,330,30,60,330,30,330,330,30,30,330,60,300,60,330,60,300,60,330,330,30,330,30,330,30,60,330,60,300,60,330,30,330,60,300,60,6990;
20;3D;DEBUG;Pulses=54;Pulses(uSec)=90,330,3960,1110,60,330,60,300,60,330,60,300,330,30,30,330,330,30,330,30,60,300,60,330,330,30,60,330,60,300,60,330,60,300,30,330,60,300,60,330,330,30,60,300,330,30,60,300,330,30,60,300,60,360;
20;3E;DEBUG;Pulses=52;Pulses(uSec)=150,1500,30,300,30,300,30,300,30,300,300,30,30,300,300,30,300,30,30,300,30,300,330,30,60,300,60,330,60,300,60,330,60,300,60,330,30,330,330,30,30,330,330,30,60,330,330,30,60,300,60,330;
20;3F;DEBUG;Pulses=52;Pulses(uSec)=150,1500,30,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,300,60,330,330,30,60,330,30,300,30,330,60,300,60,330,60,300,60,330,330,30,60,300,330,30,60,300,330,30,60,300,60,330;
20;40;DEBUG;Pulses=52;Pulses(uSec)=150,1500,30,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,330,60,300,330,30,60,300,60,330,60,300,30,330,60,300,60,330,30,330,330,30,30,330,330,30,60,330,330,30,60,300,60,330;
20;41;DEBUG;Pulses=126;Pulses(uSec)=120,300,30,300,30,300,30,300,30,300,300,30,300,30,30,300,30,300,30,300,30,300,60,300,30,2220,60,330,60,300,60,330,60,300,330,30,60,300,330,30,330,30,60,330,30,330,330,30,60,330,60,300,60,330,60,300,60,330,60,300,330,30,330,30,60,330,30,330,60,300,60,330,60,300,60,2310,60,300,30,330,60,300,60,330,330,30,60,330,330,30,330,30,30,330,30,300,330,30,60,300,60,330,60,300,60,330,60,300,60,330,330,30,330,30,30,330,60,330,30,330,60,300,60,330,60,6990;
Make Light Cooler
20;42;DEBUG;Pulses=54;Pulses(uSec)=60,180,3960,1110,60,300,60,330,30,300,60,330,330,30,60,330,330,30,330,30,30,330,60,330,330,30,60,300,60,330,60,300,60,330,60,300,330,30,60,300,330,30,60,300,330,30,330,30,60,300,60,330,60,330;
20;43;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,60,270,300,30,30,300,300,30,300,30,30,300,30,330,330,30,30,330,60,300,60,330,60,300,60,330,330,30,60,330,330,30,60,330,330,30,330,30,30,330,60,300,30,330;
20;44;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,330,30,60,330,330,30,330,30,60,300,60,330,330,30,60,330,30,330,60,330,30,330,60,300,330,30,60,300,330,30,60,300,330,30,330,30,60,330,60,300,60,330;
20;45;Doorbell;ID=5905;SWITCH=1;CMD=ON;CHIME=01;
20;46;DEBUG;Pulses=54;Pulses(uSec)=60,180,3960,1110,60,330,60,300,30,330,30,330,330,30,60,330,330,30,330,30,60,300,60,330,330,30,60,330,30,300,60,330,30,330,60,330,30,330,60,300,330,30,60,300,330,30,330,30,60,330,60,300,60,360;
20;47;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,60,300,300,30,30,300,300,30,300,30,30,300,30,300,330,30,60,300,60,330,60,300,60,330,30,330,60,330,30,330,330,30,60,330,330,30,330,30,60,300,60,330,60,330;
20;48;Doorbell;ID=5901;SWITCH=1;CMD=ON;CHIME=01;
Make Light Warmer
20;49;DEBUG;Pulses=54;Pulses(uSec)=0,240,3930,1110,60,300,60,330,60,300,30,330,330,30,60,330,330,30,330,30,30,330,30,330,330,30,60,300,60,330,30,300,30,330,60,300,330,30,60,300,330,30,60,300,330,30,30,330,330,30,330,30,60,330;
20;4A;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,30,300,300,30,300,30,30,300,30,330,330,30,30,330,60,300,60,330,60,300,60,330,330,30,60,330,330,30,60,330,330,30,60,330,330,30,330,30,60,330;
20;4B;Doorbell;ID=5905;SWITCH=1;CMD=ON;CHIME=01;
20;4C;DEBUG;Pulses=50;Pulses(uSec)=120,300,60,330,30,300,30,330,330,30,60,330,330,30,330,30,30,330,30,330,330,30,60,300,60,330,60,300,30,330,30,300,60,330,60,300,330,30,60,300,330,30,30,330,330,30,330,30,60,330;
20;4D;Doorbell;ID=5901;SWITCH=1;CMD=ON;CHIME=01;
20;4E;DEBUG;Pulses=52;Pulses(uSec)=4020,1110,60,300,60,330,30,300,30,330,330,30,60,330,330,30,330,30,60,330,60,300,330,30,60,300,30,330,60,300,60,330,30,300,330,30,30,330,330,30,30,330,330,30,60,330,330,30,330,30,60,330;
20;4F;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,300,30,330,330,30,60,330,60,300,60,330,60,300,30,330,330,30,60,330,330,30,60,330,330,30,60,300,330,30,330,30,60,330;
20;50;Doorbell;ID=5905;SWITCH=1;CMD=ON;CHIME=01;
20;51;DEBUG;Pulses=52;Pulses(uSec)=4020,1110,60,300,60,330,30,330,30,330,330,30,60,300,330,30,330,30,60,330,60,300,330,30,60,300,30,330,30,300,60,330,30,330,60,330,30,330,330,30,60,330,330,30,60,330,330,30,330,30,60,330;
20;52;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,300,60,330,330,30,60,330,60,300,60,330,60,300,60,330,30,330,30,330,330,30,60,300,330,30,60,300,330,30,330,30,60,330;
20;53;Doorbell;ID=5901;SWITCH=1;CMD=ON;CHIME=01;
20;54;DEBUG;Pulses=136;Pulses
Night Mode (e.g. very low brightness)
20;55;DEBUG;Pulses=52;Pulses(uSec)=4020,1110,60,300,60,330,30,330,60,330,330,30,60,300,330,30,330,30,60,330,60,300,330,30,60,300,60,330,60,300,60,330,30,330,330,30,60,330,330,30,60,330,60,300,330,30,60,300,60,300,60,330;
20;56;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,300,60,330,330,30,60,330,60,300,60,330,60,300,60,330,330,30,60,300,330,30,60,300,30,330,330,30,60,330,60,300,60,330;
20;57;Doorbell;ID=5905;SWITCH=1;CMD=ON;CHIME=01;
20;58;DEBUG;Pulses=52;Pulses(uSec)=4020,1110,30,330,30,300,30,330,60,300,330,30,60,300,330,30,330,30,60,330,60,300,330,30,30,330,60,330,30,330,60,300,60,330,60,300,30,330,330,30,60,330,30,300,330,30,60,300,60,330,30,360;
20;59;DEBUG;Pulses=50;Pulses(uSec)=120,300,30,300,30,300,30,300,300,30,30,300,300,30,330,30,60,300,60,330,330,30,60,330,30,330,60,330,30,330,60,300,60,330,60,300,330,30,60,300,60,330,330,30,60,330,30,300,60,330;
20;5A;Doorbell;ID=5901;SWITCH=1;CMD=ON;CHIME=01;
How can I help to get the support added for these lights?
