Hi All,
I have done the switch tutorial using ESP01 and R020 and now just need to change hardware settings from switch input to incremental count.
I want to amend the hardware settings via the web UI but can no longer access the configuration page via the new IP address as it is attempting to connect to Domoticz server from reboot.
Is there a way to amend settings without having to reflash Easy ESP from Arduino IDE starting from scratch?
Advice on a Return to Default Settings or a way to amend current settings would be greatly appreciated.
Default Settings
Re: Default Settings
You can try to connect the serial RX pin to the TX pin and boot the ESP. After boot, remove the RX-TX connection. It should reset all config data to default.
