Confirmation that data instructions were executed
Posted: 13 Feb 2017, 22:33
When I switch a light, garage door etc remotely with an App with a signal over a home WiFi to an ESP13 shield on an Arduino Uno I really would like to see confirmation that the signal was received and executed by the Arduino. A few words in a textbox on my cell phone is what I am after.
To do this I want to display a line of text transmitted by the Arduino Uno with an ESP13 shield (Settings: ESP8233-ESP13 Settings for Project 3.bmp) to a textbox on an Android cellphone. The Arduino sketch that produces the text is attached (ESP13_ESP8266_Project_3_sketch_v6_to_Android.ino). With the App TCP/UDP Test Tool I can see that the data is transmitted and received properly (PrtScr_2017-02-11_193339.jpg). When I connect my browser to the ESP13 the data appear too (Typical Browser output for Project 3.bmp), except the data only start to appear after a long delay, such as half an hour (Why? any ideas?).
To put the data in a textbox on my Android I want to use an App developed with MIT's App Inventor 2 program. To do this I used the blocks and designer code (App Inventor Blocks.bmp, App Inventor Designer.bmp, Get_Text_FROM_Arduino.aia). I could not get it to work and I could not find an example that shows how. What changes do I need to make it work?
