Hi. I need to delete all records from my rflink. As you can see I have done the command 10;RFFind;0; (and others) and still there are records 0 and others.
Im also little bit confused from learning system as I´m not sure if I could use record 0 and 1 for different devices or if 0 must be on, 1 off, 2 on, 3 off etc.
20;48;RFFIND=ON;
20;49;RFFind;x;77315C;E;2F;1;
20;4A;RFFind;x;77315C;D;2F;1;
10;RFFind;0;
10;RFFind;2;
10;RFFind;3;
20;4B;Auriol V2;ID=3F01;TEMP=8012;BAT=OK;
20;4C;Mebus;ID=4202;TEMP=801b;
20;4D;RFFind;x;77315C;E;2F;1;
20;4E;RFFind;x;77315C;E;2F;1;
20;4F;RFFind;x;77315C;D;2F;1;
20;50;RFFind;x;77315C;E;2F;1;
20;51;RFFind;x;77315C;D;2F;1;
20;52;RFFind;x;77315C;E;2F;1;
10;rfshow;
RF Record: 0 ID: F07BDA S: 09 L: 1E T: 01 - ON
RF Record: 2 ID: 941C7A S: 08 L: 1E T: 01 - ON
RF Record: 3 ID: F07BDA S: 09 L: 1E T: 01 - OFF
I use motion sensors. Codes which sends one of sensors after motion is detected is:
How to set such coded properly? I use MEGA with RXB6 receiver.
Thank you.
RFlink all records deleting
Re: RFlink all records deleting
Hi try this methode:
http://www.rflink.nl/blog2/wiring
"Reset of EEPROM settings
Connect Arduino PIN 12 to ground in order to reset settings that are stored in EEPROM."
BR,
Adam
BR,
Adam
Domoticz Beta release on OrangePI PC and BananaPI,
2x RFLink (last version),
ESPEasy, ESPEasy32 (different configurations),
MySensors (different configurations),
2x MiLight RGBW (over RFLink)
and others things
and others things
