Measuring Battery volts ESPEasy Mega
OzGrant
G'day,
Have seen a few google answers, where DEVICE is set to Analogue Input.
But I do not see that choice. I do see P025, P059, P007, and P002.
Does a PXXX for a simple analogue on A0, have to be imported/configured in some way.
danmero
Re: Measuring Battery volts ESPEasy Mega
Build 120 is too old.
See image attached below, my setup on Mega for voltage up to 19V.
Compile your own from source or try the latest nightly built from GitHub
Regards,
Edit: I add a resistor(don't remember the value) and a fuse between the car battery and A0 and do the reverse math.
Regards,
OzGrant
Tks for our reply.
I downloaded the latest firmware (GIT version: mega-20180522) and Device "Analog Input" not in the drop-down list.
Displayed choices are:
P025 Analog Input ADS1115
P060 Analog Input MCP3221[Testing]
P007 Analog Input PCF8591
P002 Analog Input Internal
If you use the VCC version you cannot use analog plugin I think?
OzGrant
Have tried:
ESP_Easy_mega-20180522_dev_ESP8266_4096.bin
ESP_Easy_mega-20180522_normal_ESP8266_4096.bin
ESP_Easy_mega-20180522_test_ESP8266_4096.bin
and
ESP_Easy_mega-20180522_test_ESP8266_4096_VCC.bin
And got the same failed result.
and
No analog at all?
OzGrant
Just the following.
I think one set did not have the Pxxx number, plus a there was [test] after the name when I viewed the drop-down selection menu.
Analog Input internal is the one that's using the ESP chips internal analog port.
OzGrant
I thought analog internal is 8266 3v3 supply and not the A0 pin.
danmero
Analog Input use A0, but can read up to internal Vcc.
If you want to go higher Vc you will need a resistor between A0 and Vc. If high current is involved please add a very small fuse inline(<=100mA).
Regards,
Regards,
OzGrant
Thanks for your help, I got confused with A0 and VCC.
Also, I like your flash programme, so its been a good day all around.
Grant
Grant
QSKONE
pls delete
Users browsing this forum: Bing [Bot] and 0 guests
