Hello.
I've found software problem, i think. Humidity value of BME280 was zero (tried two BME to test HW). But when i changed solder of BME to use address 77 - humidity works well. Then i've added second BME with address 76 and its humidity value is zero.
Is there any other information that i should give to help you to fix it?
Build 20102 - Mega
Libraries ESP82xx Core 00000000, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
GIT version mega-20180924
Plugins 72 [Normal] [Testing]
Build Md5 2ebb97ea6f45efdaa5299a9d8929e09d
Md5 check passed.
Build time Sep 24 2018 02:19:11
Binary filename ESP_Easy_mega-20180924_test_ESP8266_4096.bin
Software problem with BME280 (today RC)
Re: Software problem with BME280 (today RC)
I just checked and for me BME280 works well on this release (24.09). All values on 76 address displayed.
I did not really test multiple instances of this plugin. So if you see some issues when using multiple instances, you could see some issues.
If you have any idea on how to reproduce these issues, you're more than welcome to open an issue for it on Github.
Using mega-20180927 here with also BME280 on 0x76 and no issues.
