Problem with keypress ever 1 sec
ljmarkus
#1 Post by ljmarkus » 20 May 2019, 14:19
I use the Aurel TX6M HCS Sender and wen i pressed ever 1 sec one Key, RFLink not decode the Signal.
2019-05-20 14:08:55 - 20;05;DEBUG;Pulses=156;Pulses(uSec)=360,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,3900,660,330,660,330,660,330,270,720,660,330,270,720,660,330,270,720,270,720,660,330,660,330,270,720,690,330,270,720,270,720,270,720,660,330,660,330,270,720,270,720,660,330,660,330,270,720,660,330,270,720,660,330,660,330,270,720,270,720,660,330,660,330,270,720,270,720,660,330,660,330,270,720,270,720,270,720,270,720,660,330,660,330,270,720,690,330,270,720,660,330,270,720,270,720,270,720,690,330,270,720,270,720,270,720,270,720,270,720,270,720,660,330,270,720,270,720,270,720,270,720,660,330,690,330,270,720,660,330,660,330,660,6990;
20;06;Keeloq;ID=9e57;SWITCH=02;CMD=ON;BAT=OK;
2019-05-20 14:08:56 - 20;07;DEBUG;Pulses=156;Pulses(uSec)=360,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,3900,660,330,660,330,270,720,270,720,690,330,270,720,270,720,270,720,660,330,660,330,270,720,270,720,270,720,660,330,270,720,270,720,270,720,690,330,660,330,270,720,660,330,660,330,270,720,660,330,270,720,660,330,270,720,660,330,270,720,690,330,270,720,660,330,270,720,660,330,660,330,270,720,270,720,270,720,270,720,660,330,660,330,270,720,660,330,270,720,660,330,270,720,270,720,270,720,660,330,270,720,270,720,270,720,270,720,270,720,270,720,660,330,270,720,270,720,270,720,270,720,690,330,660,330,270,720,660,330,660,330,660,6990;
2019-05-20 14:08:57 - 20;08;DEBUG;Pulses=156;Pulses(uSec)=360,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,3900,270,720,660,330,660,330,660,330,690,330,270,720,270,720,270,720,270,720,270,720,270,720,660,330,270,720,270,720,270,720,660,330,270,720,660,330,270,720,660,330,270,720,660,330,690,330,270,720,270,720,660,330,270,720,270,720,270,720,270,720,270,720,660,330,270,720,660,330,660,330,270,720,270,720,270,720,270,720,660,330,660,330,270,720,690,330,270,720,660,330,270,720,270,720,270,720,690,330,270,720,270,720,270,720,270,720,270,720,270,720,660,330,270,720,270,720,270,720,270,720,690,330,660,330,270,720,660,330,660,330,660,6990;
2019-05-20 14:08:58 - 20;09;DEBUG;Pulses=156;Pulses(uSec)=360,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,3900,690,330,270,720,270,720,270,720,270,720,270,720,690,330,690,330,270,720,270,720,660,330,660,330,270,720,660,330,660,330,660,330,660,330,660,330,270,720,270,720,660,330,270,720,270,720,660,330,660,330,270,720,270,720,270,720,270,720,270,720,270,720,690,330,270,720,660,330,660,330,270,720,270,720,270,720,270,720,660,330,660,330,270,720,660,330,270,720,690,330,270,720,270,720,270,720,660,330,270,720,270,720,270,720,270,720,270,720,270,720,660,330,270,720,270,720,270,720,270,720,660,330,660,330,270,720,660,330,660,330,660,6990;
2019-05-20 14:08:59 - 20;0A;DEBUG;Pulses=156;Pulses(uSec)=360,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,3900,270,720,270,720,660,330,270,720,270,720,270,720,660,330,690,330,660,330,270,720,660,330,660,330,270,720,660,330,270,720,270,720,660,330,270,720,270,720,270,720,660,330,660,330,660,330,660,330,270,720,660,330,270,720,270,720,270,720,660,330,660,330,690,330,270,720,660,330,660,330,270,720,270,720,270,720,270,720,660,330,660,330,270,720,660,330,270,720,660,330,270,720,270,720,270,720,660,330,270,720,270,720,270,720,270,720,270,720,270,720,660,330,270,720,270,720,270,720,270,720,660,330,660,330,270,720,660,330,660,330,660,6990;
Whats wrong?
Thanks,
Markus
Stuntteam
Site Beheer
Re: Problem with keypress ever 1 sec
#2 Post by Stuntteam » 20 May 2019, 14:37
Nothing.
Pressing a button just shortly or pressing it very long does not generate a different signal.
This means RFlink does not need to repeat the same signal over and over.
All works as expected.
What do you believe is wrong then?
ljmarkus
#3 Post by ljmarkus » 20 May 2019, 14:48
okay,
is there any way to activate the decode the same signal?
Thanks,
Markus
