Any way to calculate Heat Index usign DHTxx plugin ? + Store the set value and use after power on
kunjmon
#1 Post by kunjmon » 24 Jul 2019, 14:17
Im making a thermostat for my brother he have a broiler chicken farm. he want to turn on and off the cooling system based on the temperature.
:?: Q-1) is their any option to turn on the cooling system based on the Heat Index calculated using Temperature & Relative Humidity using EspEasy ?. i did it before using "DHT.h" in arduino. See the images below. temperature range is between 20 to 30 °C but humidity is affecting too much, range between 35 to 60 %.
espeasy emoncms dashboard.png (165.84 KiB) Viewed 6086 times
:?: Q-2) how can i store the trigger value using web call http://<easyespio>/control?cmd=TaskValueSet,4,1,29 ? and use after the power failure.
im making a mobile app (see image below) using https://thunkable.com to control the thermostat. so my brother can easily set the trigger value. i don't want to give espeasy web ui access to him.
Thnkable mobile app.jpg (181.11 KiB) Viewed 6086 times
thunkable experience : as a ui/ux designer i like very much. its very easy to make nice looking app. using web call and json capability we can make good looking dashboards.
