RFLink Livolo IDs and Unit Codes
shalwia
#1 Post by shalwia » 10 Jan 2020, 21:21
I would like to manually add the Livolo switches to the Domoticz. After selecting the "Livolo" item from available devices list there are three parameters I need to set using trzy select lists - two parameters are related to "ID" and one to "Unit code". Is there any key how should I select values there?
Stuntteam
Site Beheer
Re: RFLink Livolo IDs and Unit Codes
#2 Post by Stuntteam » 11 Jan 2020, 01:51
What you are trying to do is not possible.
For RFlink there is no Livolo setting in Domoticz.
Read: http://www.rflink.nl/blog2/faq
and scroll to
Q: how to create devices in Domoticz without the original remote control?
shalwia
#3 Post by shalwia » 24 Jan 2020, 21:36
Stuntteam wrote: 11 Jan 2020, 01:51 Read: http://www.rflink.nl/blog2/faq
I’ve already ready it. The Livolo model is not mentioned there (there are Impuls, Kaku, EMW203R), so is there any possibility to control Livolo them using such a codes?
The thing is that Some of the codes (randomly set on the basis of “ID’s” and “Unit codes” seems to be working - after the switch is added manually it’s triggering the Livolo switch correctly. But its a lottery...
