MQTT Publish - correct syntax?
pw444
#1 Post by pw444 » 28 Dec 2020, 15:45
Hya,
i have the follwing rule, but something is wrong, as MQTT Explorer does not shows the change of state as published.
on MQTTsniff#BOFF do
  if [MQTTsniff#BOFF]=1
      Publish,%sysname%/BOFF/status/1
      pulse,13,1,500
      pulse,2,0,500
      Publish,%sysname%/B24/status/0
      Publish,%sysname%/B58/status/0
on MQTTsniff#B58 do
  if [MQTTsniff#B58]=1
     Publish,%sysname%/B58/status/1
     pulse,14,1,500
     pulse,2,0,500
     let,1,1
     Publish,%sysname%/BOFF/status/0
on MQTTsniff#B24 do
  if [MQTTsniff#B24]=1
     Publish,%sysname%/B24/status/1
     pulse,12,1,500
     pulse,2,0,500
     let,1,1
Is the Publish,%sysname%/BOFF/status/0 correct, as i'm not finding a conclusive answer?
Thx in advance.
Re: MQTT Publish - correct syntax?
#2 Post by TD-er » 28 Dec 2020, 15:55
First thing that comes to mind is that you must check if the topics you're looking at on the broker need a leading /
You're not sending one and that's the way how (I think) it should be, but it is a very common mistake to make that on one system you're using a leading / in the topics and not on the other one.
Another thing is this:
As it is also the event, you may want to refer to it as %eventvalue1%
Events are being queued, so the task variable may already have been changed.
But the value as it had when creating the event is stored in the eventvalues. (%eventvalue1% ... %eventvalue4%)
dynamicdave
#3 Post by dynamicdave » 29 Dec 2020, 09:28
I would have thought the publish command should be...
Publish,%sysname%/BOFF/status,1
Publish,%sysname%/BOFF/status,0
#4 Post by TD-er » 29 Dec 2020, 10:04
Yep you're right, the publish is missing a message as it has only a topic.
Missed that one.
pw444
#5 Post by pw444 » 29 Dec 2020, 13:22
dynamicdave wrote: 29 Dec 2020, 09:28 I would have thought the publish command should be...
Ok, thank you. Will try out and return.
The intend is to have on ESPEasy all the logic for MQTT.
The Controller: HA
The device: 3 push buttons.
On HA i have the card with these three buttons, as slide.
Any of the buttons shall remain ON for 1 second and then OFF again. And when ON, the state of the two other buttons shall become 0, so the button gets OFF. And i want to do it using MQTT.
On HA, MQTT is used to trigger any of these 3 buttons on ESPEasy.
pw444
#6 Post by pw444 » 29 Dec 2020, 13:28
TD-er wrote: 28 Dec 2020, 15:55 As it is also the event, you may want to refer to it as %eventvalue1%
ok, and how shall i know which is %eventvaue1%, %eventvalue2% and so on , given the following rules?
// setup
// http://192.168.1.7/control?cmd=event,OffAll_Off
// http://192.168.1.7/control?cmd=event,On24_On
// nothing - status idle - no notification - status working 0
// started manually - set VAR#0  1 - remote set VAR#0 0
// started - mqtt - remotelly - set status working 1 set remote 1
// finnished - status working 1 and remote 1? - notification - status working 0 set remote 0
// finnished - status working 1 and remote 0? NO notification - status working 0 set remote 0
// publish idle, working, remote  --- 000, 010, 011
On System#Boot do
// GPIO,2,0  // status led - inversed - 1 OFF, 0 ON
 GPIO,12,0 // pb 2-4 PB24
 GPIO,14,0 // pb 5-8 PB58
 GPIO,13,0 // pb off PBOFF
// GPIO,4,0 //  ACC sense  // do not set, because it messes up the input - by hardware and devices
  Monitor GPIO,4  // D2
  let,1,0
on MQTT#Connected do
  event,publishstatus
// loop
On B58 do               // B58 - gpio 14 - D5
  pulse,14,1,500
  pulse,2,0,500
  let,1,1
On B24 do               // B24 - gpio 12 - D6
  pulse,12,1,500
  pulse,2,0,500
  let,1,1
On BOFF do              // BOFF - gpio 13 - D7
  pulse,13,1,500
  pulse,2,0,500
on MQTTIN#BOFF do
  if [MQTTIN#BOFF]=1
      pulse,13,1,500
      pulse,2,0,500
on MQTTIN#B58 do
  if [MQTTIN#B58]=1
     pulse,14,1,500
     pulse,2,0,500
     let,1,1
on MQTTIN#B24 do
  if [MQTTIN#B24]=1
     pulse,12,1,500
     pulse,2,0,500
     let,1,1
on VACC#status do
  if %eventvalue%=1  // status = 1
    if %v1%=1        // status = 1 var1 = 1
       logentry,"Working"
  else               // status = 0
    if %v1%=1        // status = 0 var1 =1
       let,1,0
       logentry,"Finished"
#7 Post by Ath » 29 Dec 2020, 13:49
pw444 wrote: 29 Dec 2020, 13:28 ok, and how shall i know which is %eventvaue1%, %eventvalue2% and so on , given the following rules?
Within every such event handler (on ... do ... endon) there are 4 eventvalue variables available, %eventvalue% and eventvalue1% (that's the same), %eventvalue2%, %eventvalue3% and %eventvalue4%
Whether there is any useful data in those variables depends on the event source, but for a 'normal' state-change, the new value is in %eventvalue%, and eventvalue2..4 are 0.
When sending an event command you can provide any values yourself, like 'event,B58=1,2,3,4' and the values 1..4 will correspond with the eventvalue variables 1..4 (as said, %eventvalue% and %eventvalue1% are the same, just a way to avoid a common typo, and keep backward compatibility).
pw444
#8 Post by pw444 » 29 Dec 2020, 14:01
ok, so the following rule will work, and for every event on... do ...endon, %eventvalue% will referr to the status of the given event, correct?
on MQTTIN#BOFF do
  if %eventvalue%=1
      pulse,13,1,500
      pulse,2,0,500
on MQTTIN#B58 do
  if %eventvalue%=1
     pulse,14,1,500
     pulse,2,0,500
     let,1,1
on MQTTIN#B24 do
  if %eventvalue%=1
     pulse,12,1,500
     pulse,2,0,500
     let,1,1
on VACC#status do
       logentry,"Working"
  else               // status = 0
       let,1,0
       logentry,"Finished"
#9 Post by Ath » 29 Dec 2020, 15:20
Correct.
As TD-er already explained, these are the values that get sent with the event into the queue of events to be processed, so are the values of the moment the event trigger was generated.
#10 Post by TD-er » 29 Dec 2020, 16:14
For debugging it is also useful to send the values to log like this:
logentry,'Event Values: %eventvalue1% %eventvalue2% %eventvalue3% %eventvalue4%'
pw444
#11 Post by pw444 » 29 Dec 2020, 17:45
Thank you! It's working as intended..... MQTT, etc... all working. Nice support guys :)
Now i only have to make sure that user get's notification when finnished.
// setup
On System#Boot do
  let,1,0
  event,publishstatus
// loop
// events triggered by http
  pulse,14,1,500
  pulse,2,0,500
  let,1,1
  pulse,12,1,500
  pulse,2,0,500
  let,1,1
  pulse,13,1,500
  pulse,2,0,500
//  Publish,%sysname%/BOFF/status/0
// events triggered by MQTT
on MQTTIN#BOFF do       // cancelled
  if %eventvalue%=1
     pulse,13,1,500
     pulse,2,0,500
on MQTTIN#B58 do       // brew 5-8
  if %eventvalue%=1
     pulse,14,1,500
     pulse,2,0,500
     Publish,%sysname%/B58/status,0
     let,1,1
on MQTTIN#B24 do        // brew 2-4
  if %eventvalue%=1
     pulse,12,1,500
     pulse,2,0,500
     Publish,%sysname%/B24/status,0
     let,1,1
on VACC#status do
       logentry,"Working"
  else               // status = 0
       let,1,0
       logentry,"Finished"
       // trigger to notify - finnished
#12 Post by TD-er » 29 Dec 2020, 21:49
You can send an email, or attach a speaker (and using the buzzer) or use another GPIO pin to trigger a siren :)
