Dear Community,
my name is Ben and I am more the mechanical engineer type of guy than a coder.
Anyway, I am very interested the ESP Easy Project and wanted to dive into this world with building myself some cheap air-quality sensors with a small display to use it in different spaces and later on being able to integrate it in a smart-home enviroment.
I stumbled over the "DustSensor" from wojked that had a neat Design and seemed to work with less components.
The tutorial is easy to understand and I think i can do this without big issues.
Sadly there is no CO2 Sensor implemented in his design, so I checked the ESP Easy website if there is some CO2 Sensors that I can use and recognized the MH-Z19 that seemed to have an existing plugin. (https://espeasy.readthedocs.io/en/lates ... ght=MH-Z19)
I asked myself if it is a big deal to use this sensor additionally in the DustSensor-Setup to additionally have the Display of the WEMOS NodeMCU showing also the CO2 Levels.
Would be really nice to get some kick-start into this project from you guys.
Best regards
BEN
DustSensor (by wojked) - adding a CO2 Sensor
Re: DustSensor (by wojked) - adding a CO2 Sensor
Hi Ben,
Both the Dust and CO2 sensors you seem to mention (didn't find "the "DustSensor" from wojked"" but I assume it's a SDS011 or PMSx003 device) are supported in the Climate build, so you can install that on your ESP.
That Climate build has support for OLed screens.
You are 100% right with the SDS011. I will go for the MH-Z19 and try it out.
Hope everything works out fine, otherwise you will here from me soon.
Thanks Ton!
Best
BEN
Thanks Ton!
Best
BEN
Hey!
Do not hesitate to also write me if you have any issues.
Let me know how did it go!
Greetings,
wojked
P.S. Kudos to the “lets control it” team!
Greetings,
wojked
Hi there. Here I found how to make a CO2 meter with ESPeasy using Senseair S8 sensor. It has some advantages over MH-Z19. I think you'd like to take a look.
https://emariete.com/en/meter-co2-esp82 ... nseair-s8/
By the way, MH-Z19 is good also. With that, you can also make many versatile PCBs like this:
https://www.pcbway.com/project/sharepro ... ector.html
