This message just demonstrates how much time you can spend by a wrong starting assumption and/or wrong information .......
Found time to connect the received SHT11.
To avoid conflicts with the OLED on 'real' I2C (and in fact no choice, because then GPIO4+GPIO5 not made available for selection), similar to I2C at GPIO04 and GPIO05, start with SCL/SCK= D6/GPIO12
at 1st GPIO and SDA = D7/GPIO13
at 2ndGPIO
Under tab 'Devices/Edit' selected SHT1X, set PullUp and set Enabled, and then the 'Devices'-display shows values.
So far OK, but apparently missmatch with the 'standard' driver-software for SHT1X, because I get the display below, while I expect something like (at this moment) approx. 24 degreesC and 55%RH. The displayed values remain fixed regardless of changes in the environment.
In hindsight, these values are displayed if no sensor is connected and ESPEasy has the settings mentioned above ..........
- ESP8266+ESPEAsyMega+SHT11+GPIOSet
- Knipsel_ESP8266F_170821.JPG (66.39 KiB) Viewed 31525 times
If the result is not as expected, you look in detail & experiment ......
Putting the device-data&clock on GPIO04+GPIO05 and performing I2C-scan does not yield results => device is not I2C [
as to be expected]
Opening the sensor-head does not help to get info, because the sensor-pcb is nicely shielded&coated.
- SHT11_opened
- IMG_SHT11_Open.jpg (33.87 KiB) Viewed 31508 times
Looking at the interface-side, I left the SHT-device hardware connected to D6 and D7, but did not set the GPIOs in ESPEasy:
then you get the result below (again with 'frozen' values).
- ESP8266+ESPEasyMega+SHT11+GPIOnotSet
- Knipsel_ESP8266F_170821A.JPG (61.31 KiB) Viewed 31514 times
Exchanging the wires on D6 and D7 has no results, hence certainly not the remedy .......
Then another idea popped-up ......
Switch SDA = yellow = D7/GPIO13
to 1st GPIO and SCL= blue = D6/GPIO12
to 2nd GPIO
That is the correct/working setting!
But the opposite of the information in the Wiki!
=> Careful conclusions
1) lack of colourcoding for the cable => a lot of effort to find out the operational configuration
2) WEMOS & SHT11 can accept/survive quite a lot of molesting .....
- ESP8266+ESPEasyMega+SHT11+reversedGPIO
- Knipsel_ESP8266F_170821B.JPG (63.65 KiB) Viewed 31497 times
