need some help with atom
GravityRZ
#1 Post by GravityRZ » 05 Apr 2020, 18:16
I followed the tutorial on https://www.letscontrolit.com/wiki/inde ... platformio
but still atom gives me errors
i selected espeasy.ino
pressed F7 and selected normal_esp8266_4m1m
i see this at the beginning, do i need to remove the ifdef and last endif
#ifdef PLUGIN_SET_GENERIC_ESP32
  #ifndef ESP32
    #define ESP32
  #endif
#endif
how do i add plugin P222 (downloaded it in the same directory)
this is the error i get
Fetched in submodule path 'tools/sdk/lwip2/builder/lwip2-src', but it did not contain 159e31b689577dbf69cf0683bbaffbd71fa5ee10. Direct fetching of tha
t commit failed.
Submodule path 'tools/sdk/ssl/bearssl': checked out '89454af34e3e61ddfc9837f3da5a0bc8ed44c3aa'
Failed to recurse into submodule path 'tools/sdk/lwip2/builder'
Error: VCS: Could not process command ['git', 'clone', '--recursive', '--depth', '1', '--branch', '2.6.3', 'https://github.com/esp8266/Arduino.git', '
C:\\Users\\Ronald\\.platformio\\packages\\_tmp_installing-thtva5t2-package']
guy67400
Re: need some with atom
#2 Post by guy67400 » 05 Apr 2020, 19:10
I got similar error - it seems, one can not compile ESPEasy with Platformio => use arduino IDE.
(gmella helped me in this for P_127 - see https://www.letscontrolit.com/forum/vie ... f=6&t=6249)
How to :
- download and install arduino IDE (arduino-1.8.9)
- to setup arduino ide follow https://www.letscontrolit.com/wiki/inde ... are_Upload
chapter Launch arduino.exe and select preferences
and chapter Now navigate to the board manager
- git clone or download espeasy repository
- move, copy or link ESPEasy/src to ESPEasy/ESPEasy so the arduino IDE does not complain when you open the project with ESPEasy/ESPEasy/ESPEasy.ino
- copy/synchronize ESPEasy/lib content to my main ARDUINO/libraries
- open ESPEasy.ino in arduino
- compile
GravityRZ
Re: need some help with atom
#3 Post by GravityRZ » 06 Apr 2020, 12:25
i will try it out.
i used to use arduino (which i got working some time ago) but lately it is only giving errors
it amazes me that all these platforms are not idiot proof(yes i am the idiot)
how hard is it to make 1 package which compiles out of the box
all these dependencies are killing functionality.
GravityRZ
#4 Post by GravityRZ » 06 Apr 2020, 15:18
ok.
managed to build it with the p222 debounced counter.
seems not the same as generic counter.
debouncetime max 800ms
output only 2 (delta/total) so i am missing time
so for my usage (watermeter counter) totally useless.
well at least ik know how to create a modiied build.
strange thing is the original compiled well
as soon as i modified it i needed to save it. after that i got an error about ramtracker.
what i did then is just modify the define_plugin_sets.h file in the original build and that was working.
so saving a new version (all new files were put in a new directory) did not work
#5 Post by TD-er » 06 Apr 2020, 16:20
Try a different version of Git.
See: https://github.com/letscontrolit/ESPEas ... -609767750
GravityRZ
#6 Post by GravityRZ » 08 Apr 2020, 14:55
ok, will test when i have some spare time.
for now i am using arduino again
arduino was working perfectly, then it stopped(could not get it to work again)
now i did a fresh reinstall and it worked instantly
upgraded to arduino 1.8.12 and still working.
i build with arduino but flash with espflasher because i have special characters in my SSID which i can not enter manually but can do with post processing in espflasher
GravityRZ
#7 Post by GravityRZ » 11 Apr 2020, 19:44
well tried platformio again but still errors
installed atom 1.45.0
installed platformio-ide 2.6.0
installed git 2.25.0 (because latest version 2.26 gives error)
also very annoying, i can hardly find a git windows executable lower than 2.26
why make it not possible to download previous versions in windows exe format.
i need to compile my own version so that i can fix installing a compiler error in atom !!!!!!!
now i get this one
Compiling .pio\build\normal_ESP8266_4M1M\FrameworkArduino\base64.cpp.o
lib\SC16IS752\SC16IS752.cpp:25:17: fatal error: SPI.h: No such file or directory
#8 Post by grovkillen » 11 Apr 2020, 21:12
PlatformIO is heavily dependent on Python being installed correctly. Is your PATH populated with Python install folder path?
https://www.computerhope.com/issues/ch000549.htm
I find it really straight forward if Python is installed correctly, just download the zip from github and open it in Atom/PlatformIO.
GravityRZ
#9 Post by GravityRZ » 11 Apr 2020, 21:53
ok. i will try again.
GravityRZ
#10 Post by GravityRZ » 12 Apr 2020, 11:04
finally got it working but it was no breeze.
maybe when atom was running ok i tested it on an old build which i used for arduino (src directory renamed to ESPEasy)
tested it again on latest build and pointen it to the source directory.
not sure if this was the only problem but at least it is working.
also tested this build if i can update using OTA on the ESP and it did.(with arduino this does not work)
Users browsing this forum: Bing [Bot] and 139 guests
