Stepper support request; for curtain automation <€30
Posted: 12 Dec 2016, 01:11
Impressed by reading about ESP Easy, great job done!
My request in short: please consider support for the universal A4988 stepper motor driver module:
- select 1 out of 5 step modes
- select direction
- give it a number of pulses
Background:
I'm currently in the conceptual design phase of automation of a set of wave curtains (4 and 2.5meter).
I have selected the Haydon AMETEK-LC1574-W linear stepper motor (15mm x 40mm).
http://www.haydonkerk.com/?TabId=86
By adapting the white cover, it can be used as a rotating stepper motor (remove the cover, saw a few mm off, and the 2mm axis can rotate freely) The 2mm axis is hidden under the black cover.
Cost €4.53, bought here(only the 4V (!) version is available):
https://nl.aliexpress.com/item/Mini-lin ... =100007153
Strong enough (7N) and accurate enough for closing a 4meter curtain with approximately 2500 steps in around 25seconds.
The stepper motor mounting on DIN rail will be done with a M12 nylon nut on the white cover.
I have selected the A4988 stepper motor driver module.
https://www.pololu.com/product/1182 Cost €0.73, bought here:
https://nl.aliexpress.com/item/5pcs-lot ... Title=true
- the A4988 has a translator for step modes: one pulse,one step.
- the Vreff adjustment enables Voltage/Current limitation (needed for the 4V/0.2A Haydon stepper).
Simple control:
- select 1 out of 5 step modes (selector inputs pin MS1, MS2, and MS3)
- select direction (DIR pin)
- give it a number of pulses (STEP pin)
A nylon fishing line will be winded/unwind-ed (at the same time) on two spools on the stepper axis:
https://nl.aliexpress.com/item/10x-Dura ... Title=true The 2mm axis goes via a shaft coupler to 5mm to hold the 2 spools.
https://nl.aliexpress.com/item/5pcs-lot ... 28631.html
The fishing line is guided by Nylon U groove ball bearings: https://nl.aliexpress.com/item/2pcs-Nyl ... Title=true
Additional needs:
- 0.3 mm breaded fishing line
- 50cm DIN rail
- project box mounted on DIN rail
- ESP board
- 2x power supply (TSP-05 and TSP-12)
- plugs (XS8 2Pin and XS8 4pin) ( https://nl.aliexpress.com/store/1724883 ... t=xs8+plug )
Total cost < €30 per curtain
For another 5 small windows of 80cm I have planned to use a 2GT belt with 2GT pulleys
https://nl.aliexpress.com/store/group/2 ... 78143.html I hope this will inspire others
and ... to get support for the A4988 stepper driver included in ESP Easy.
Domosapiens
- select direction
Background:
Simple control:
Additional needs:
- 50cm DIN rail
- ESP board
Domosapiens
