I setup a push button (physically attached to GPIO13/D7 to one of my unit) as per below:
No matter what I setup (I tried literally everythign!) once I press the button I've an immediate change of its status to "1" that is triggering a relay.
But it takes around 1300ms (as per below screeshot) after I release the button until the device status is back to 0; this means if someone push the button meanwhile nothing happens!!!
How can I have immediate reset of device status once button is released?
I've a virtual switch on node-red that sends on/off command to the same relay and this is perfectly working and I can send command once after the other without delays or lags.
If anyone can help or address me to the right piece of code handling this behaviour I'll be very thankfull...
