Domoticz/ESPEasy: Wemos D1 not sending data
bertrand
#1 Post by bertrand » 17 Oct 2016, 18:17
Hi Guys,
I have a Domoticz setup with several type of nodes running ESPeasy. As I can't register on Domoticz forum, here is my issue:
- Domoticz has been running for months
- I have MySensors nodes with RFM69W gateway running well
- I have ESPeasy nodes on NodeMCU that are perfectly stable
- I just bought some Wemos D1 (Chinese versions) with DHT22 shields
But when there is no data, I can connect the ESP node and check the values in /devices... and they are good (not 0).
Any ideas ?
I have this issue with the DHT Pro (DHT22) shields... but the same nodes have DS18B20 and they transmit their data without any issue...
nonflammable
Re: Domoticz/ESPEasy: Wemos D1 not sending data
#2 Post by nonflammable » 17 Oct 2016, 22:07
Try to add capacitor eg. 470uF between 3.3V and GND pins.
bertrand
#3 Post by bertrand » 18 Oct 2016, 18:18
Thanks !
I'll give a try.
papperone
#4 Post by papperone » 18 Oct 2016, 19:46
Sorry for the OT, can you please tell how those graph/chart are generated? It is some kind ok automation software?
costo
#5 Post by costo » 19 Oct 2016, 00:00
papperone wrote:Sorry for the OT, can you please tell how those graph/chart are generated? It is some kind ok automation software?
Like bertrand says
bertrand wrote: I have a Domotic setup with several type of nodes running ESPeasy.
http://www.Domoticz.com
Domoticz runs best on a Raspberry Pi. It is a very nice piece of software. Lots of hardware can communicate with Domoticz. The database can store a lot of data and all sort of charts are generated for easy interpretation of the data.
You should try it. it makes you independent of all the web-based solutions and when your network is properly configured you can access your domoticz server from everywhere.
Users browsing this forum: OpenAI Searchbot [bot], opensiteexplorer.org/dotbot [bot] and 26 guests
