Config not saving correctly
casi99
#1 Post by casi99 » 26 Sep 2015, 22:27
Hello together,
I have flashed the latest version, 23 on my Olimes dev board and counter some Problems:
1. Mainsettings: changing the WPA AP Mode Key doesn´t work on my unit, in version 20 there was no problem--> have only I the problem?
2. Tools: settings-load safe list didn´t work correctly: save works, a config.txt file will be downloaded, when i upload this file it didn´t appear in the list when i press the list button --> same question as on 1
can you help please?
br
Carsten
2xESP8266 Olimex dev. board for testing
5xESP8266-01 for dimmer, switches, relays
2xESP8266-12E for relays and dimmer
Martinus
Re: Config not saving correctly
#2 Post by Martinus » 27 Sep 2015, 11:19
Hello Carsten, thanks for joining in...
About your findings:
casi99 wrote:I have flashed the latest version, 23 on my Olimes dev board and counter some Problems:
You've discovered a recent bug. Fill be fixed with the next release.
casi99 wrote:Hello together,
This is strange as the file should already be in the list after a fresh install. Or does it get wiped after uploading a new one?
You may be the only one with this problem, but hard to tell. At present, we only have a limited set of users, especially the ones running on the latest development source...
casi99
#3 Post by casi99 » 29 Sep 2015, 13:56
i will test it again with the new release.
I hope I can give you an answer tomorrow.
Thanks for your investigation and support.
br
Carsten
casi99
#4 Post by casi99 » 29 Sep 2015, 16:35
I have tested it but it didn´t work.
Using R25
What Ia have done:
1. going to "Tools" -> Settings:List
nothing viewed in the list (tested under WIN with IE10, Firefox and on my MAC)
2. Save the config file works
3. Upload config file also works
4. reboot
5. going to "Tools" -> Settings:List
It is not urgent for me ;-)
I´m starting first with ESPeasy and Domo and have to learn much more before
br
Carsten
Users browsing this forum: Anthropic Claude Bot [bot] and 12 guests
