Documentation improvement by community
grhhm
#1 Post by grhhm » 24 Oct 2016, 16:43
Hi there,
Sometimes (example is below) a clarification is required for some features of ESP-Easy. The documentation is based on wiki. How it is possible to edit/improve pages? Is this under admin/moderator only?
My proposal for improvement:
Page: http://www.esp8266.nu/index.php/ESPEasy
Statement: If you run a different protocol, it can be any value but must be non-zero. Just choose '1' in those cases...
Correction: For Thingspeak (TS) protocol IDX field must indicate the chart number on the TS channel. The variable name should be the same as defined on chart of TS: field1, field2, etc. If you run a different protocol, it can be any value but must be non-zero. Just choose '1' in those cases...
Thank you.
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot], Perplexity.ai [bot] and 9 guests
