UV
Dylantje
UV
#1 Post by Dylantje » 17 Apr 2016, 18:46
Dear developers...
Is there perhaps a option that the a UV sensor is going to work with the ESPeasy ....
Great option for my terrarium..
fluppie
Re: UV
#2 Post by fluppie » 17 Apr 2016, 21:45
Dylantje
Re: UV
#3 Post by Dylantje » 17 Apr 2016, 21:52
And is this working with espeasy or seperate..
I try to make a combi sensor.
The max pins to switch some lights and heater
And some sensors
Only i mis uv in the espeasy list
Ton_vN
Re: UV
#4 Post by Ton_vN » 24 Oct 2016, 16:38
@Dylantje
The ML8511 and GUVA-S12SD devices from Adafruit (or direct from China) generate a DC-Voltage which can be interfaced to the ADC-interface of the ESP8266:
support by ESPEasy is simply as an analogue signal at the ADC-port.
If you want UV-measurement digitally by means of the I2C-interface, the SI1145-breakout or the VEML6070-breakout are candidates.
For SI1145 an ino-file is available at this forum. For VEML6070 I did not (yet) see any support.
This url https://learn.adafruit.com/adafruit-vem ... r-breakout summarizes the differences between the various options.
Dylantje
Re: UV
#5 Post by Dylantje » 24 Oct 2016, 19:38
Dear Ton.
Do not have time for this @ the moment..
When i have time hope you wil help me..
Thanks for your post
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 11 guests
