I have created a sysinfo device (name: sysinfo, value name 1: rssi) for Wifi RSSI
To display it on a 20x4 LCD I use "U: %uptime% min R: [sysinfo#rssi] dBm"
This worked in R80 but seems to be broken in R91
The values gets published to my MQTT broker just fine
The display shows "U: 3 min R: dBm"
Anyone else seeing this issue?
- Jan
sysinfo/rssi not shown on LCD
Jan Chrillesen, Denmark
Re: sysinfo/rssi not shown on LCD
Work on version 91/92 LCD2004
at mine
RSSI:[Sys.info#RSSI]dBm
RSSI:[Name#Values]dBm
Hope to work for you.
Petko
at mine
Petko
same issue on my OLED using R91. Only showing:
RSSI:dBm
RSSI:dBm.
Yo
RSSI:dBm
RSSI:dBm.
Yo
Thank you for confirming that I'm not the only one seeing this issuevoyager46 wrote:same issue on my OLED using R91. Only showing:
RSSI:dBm
RSSI:dBm.
- Jan
I have exactly same problen on version 140.
Any help?
Any help?
Yeah, same here on latest firmware!
Ohh, okay, a complicated way!
