one-ESP node command does not work
ym58
#1 Post by ym58 » 07 Nov 2016, 06:02
To make a long story short, I've made a few pics to show my problem to the community !
Thanks for any hint .... :idea:
costo
Re: one-ESP node command does not work
#2 Post by costo » 07 Nov 2016, 15:50
Did you do a reboot ?
Nescessary to make the nodelist and UDP work.
ym58
#3 Post by ym58 » 07 Nov 2016, 16:46
costo wrote:Did you do a reboot ?
Yes of course, I rebooted right after setup (2) so to make sure the node list and setup are refreshed ...
Actually, I am wondering whether sending a 'command' via the 'tools' menu ***ONLY*** works on other EPSs in the node list and ***NOT*** on oneself ???
hvdwolf
#4 Post by hvdwolf » 07 Nov 2016, 18:30
In the wiki it says "SendTo" while you have "sendto".
Did you try whether the command is case sensitive?
The rules section also uses case-sensitive commands.
ym58
#5 Post by ym58 » 07 Nov 2016, 19:25
hvdwolf wrote:In the wiki it says "SendTo" while you have "sendto".
No way, it makes no difference, my LED 's still dumb !!!
papperone
#6 Post by papperone » 07 Nov 2016, 19:45
I did not try but could make sense, why you should send a command to the same node you sent it from?
ym58
#7 Post by ym58 » 07 Nov 2016, 20:40
out of consistency !
a node is a node, no matter what ...
hvdwolf
#8 Post by hvdwolf » 07 Nov 2016, 22:32
You are very stubborn. First read the wiki (http://www.letscontrolit.com/wiki/index ... rial_Rules) and then search this forum. You can't send a message to yourself.
I had not looked at that as I could not imagine you would try that.
Edit: As far as I know the UDP protocol does not even allow that.
ym58
#9 Post by ym58 » 08 Nov 2016, 06:24
hvdwolf wrote:You are very stubborn. First read the wiki (http://www.letscontrolit.com/wiki/index ... rial_Rules) and then search this forum. You can't send a message to yourself.
"Very stubborn" ... :o ?
Well, let's just say that I was looking for a simple kinda 'GUI-like' way to send commands to my ESP module that would spare me typing URLs such as http://192.168.11.110/control?cmd=gpio,13,0 in the address bar of my browser!
Sorry about the 'disturbance' ... ;)
papperone
#10 Post by papperone » 08 Nov 2016, 06:54
I have been looking into the code and indeed I think it's like that both by design and probably by used protocol limit (UDP).
I'm not sure what you want to achieve but if you need to send command to the same node from it's own ESPEasy GUI then just type it! Use "gpio,13,0" instead of "SendTo 1,gpio,13,0", it works smooth and perfectly :)
ym58
#11 Post by ym58 » 08 Nov 2016, 08:44
papperone wrote:I have been looking into the code and indeed I think it's like that both by design and probably by used protocol limit (UDP).
Gosh ... how could I have missed that ?
I think I am ***REALLY*** more stupid than stubborn, actually !
Thanks papperone for this constructive advice ... :idea:
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 22 guests
