ESPEasy works quite well on WemosD1 and Witty Cloud devices using a DHT22 sensor. Thanks a lot for this great sw!
Unfortunately I cannot get any DS18b20 temp sensor working. The boards are powered by 2A power-banks. The IDX / Var is definitely NOT zero. I tried different values (1, 2, 22, 77, 120, etc.) to no avail.
One single time the ESP could read the 1-wire id of the sensor. But, whenever I reflash or reboot the sensor id is 0-0-0-0-0-0-0-0 and the temperature always shows as 0.0. (BTW, it is unfortunate to show a not uncommon temperature as error value, I'd prefer NaN or 85.0)
Using the Arduino library with my own program or with Homie and a competely untouched same wiring, I can perfectly read correct ids and temperature values.
regards
RE:
ds18b20 always reads zeroes
Re: ds18b20 always reads zeroes
BTW, I tried the following firmware versions: 78, 108, 120, and 137
The log shows:
9214976 : WD : Uptime 153 ConnectFailures 0 FreeMem 26960
9214977 : WD : Uptime 153 ConnectFailures 0 FreeMem 26960
9230940 : DS : Temperature: 0.00 (28-57-47-f3-6-0-0-25)
9244978 : WD : Uptime 154 ConnectFailures 0 FreeMem 26960
9274979 : WD : Uptime 154 ConnectFailures 0 FreeMem 26960
9291000 : DS : Temperature: 0.00 (28-57-47-f3-6-0-0-25)
9304980 : WD : Uptime 155 ConnectFailures 0 FreeMem 26960
9334981 : WD : Uptime 155 ConnectFailures 0 FreeMem 27040
9351148 : DS : Temperature: 0.00 (28-57-47-f3-6-0-0-25)
RE:
The log shows:
RE:
I realized that the problem does not exist on pin 2 (D4). ESPEasy detects all sensors and reads perfectly well all data if the 1-wire sensors are attached to pin2. At other pins the sensors do not get detected or always read zero.
What is so special about GPIO-2 (D4) on the Wemos D1 mini?
Which version are you using? The waterproof ones, stainless steel end on the long black cable generally have a pull-resister built in. Check the schematic on the wimos, it may have a pull-up on GPIO2.
The datasheet for the ds18b20 shows a 4.7k pullup from VCC to data. This is also in other threads in the forum, a search on ds18b20 should have found it, searching on ds18b20 and wemos might be even more helpful.
Also it is a good idea to have the data sheets for components you use handy, they can be very helpful.
Can you please confirm you wired a 4.7k resistor between VCC and DATA of the DS18B20? This is mandatory to have it properly working.RE: wrote:I realized that the problem does not exist on pin 2 (D4). ESPEasy detects all sensors and reads perfectly well all data if the 1-wire sensors are attached to pin2. At other pins the sensors do not get detected or always read zero.
Regarding the different PIN behavior D4 and D3 in the WeMos D1 mini have a pull-up resistor (so in theory they shoudl act the same).
On top of this the D4/GPIO2 is connected to the blue built-in LED of the WeMos, but I'm not sure it shoudl make any difference...
I have a bunch of Wemos D1 mini boards, and without further thinking I just wired the water-proof DS18B20 sensors to D4. Just because it's next to +5V and GND. And they all work beautifully.
https://wp.josh.com/2014/06/23/no-exter ... mp-sensor/
Users browsing this forum: Anthropic Claude Bot [bot], Perplexity.ai [bot] and 21 guests
