Is there a way to reset the ESP with ESPEASY using the command option ? (this because the ESP i talk about is build in a lamp)
Or is there an other way to set this ESP back to AP mode ?
reset ESP by command
Re: reset ESP by command
Yes,
reset
That's factory reset ?nonflammable wrote:Yes,Code: Select all
reset
The issue I've got that this esp is getting the wrong IP .it was working for months without any problem. But a few days ago it get the wrong IP even when the IP was fixed in the DHCP server and on the esp itself.
Can you inplement a factory default input...
The general idea is when nothing else works you want to reset to factory default...
Ok reflashing should do just that but it would be (esp)easy to have just a button to factory default..
Maybe using one GPIO to make this posible...
Benno
Benno
You can reset the current version, or remove all the settings by connecting RX to TX and powering on for a few minutes, turn off, remove TX-RX connection and reboot. It should show up as a AP but you have to re enter all the settings.
Users browsing this forum: Anthropic Claude Bot [bot] and 21 guests
