controlling a switch externally by http breaks ESP ?
kr0815
#1 Post by kr0815 » 12 Nov 2016, 17:55
I defined a switch, ussing it in rules to switch my PIR activated light only at night.
On sunrise / sunset, this switch is externally controlled by
curl 192.168.178.46/control?cmd=GPIO,2,1
This works for a few weeks, then this input / output is dead
ESPEasy still answers with
"log": "GPIO 2 Set to 1",
"plugin": 1,
"pin": 2,
"mode": "output",
"state": 1
But even in the webinterface in Devi´ces section, GPIO2 stays at 0
This happened with one GPIO a few weeks ago, i switched then to the next one, now also broken...
any suggestions ?
costo
Re: controlling a switch externally by http breaks ESP ?
#2 Post by costo » 13 Nov 2016, 11:54
What did you exactly connect to gpio2 ?
Outputs can get damaged if current is greater than 12mA.
kr0815
#3 Post by kr0815 » 13 Nov 2016, 12:19
There is nothing connected, i only use it as a dummy device, switch it on/off externally and check in a ruie the switch state
Also pull-up is disabled in settings
Could it be there is a bug and i destroyed the pin using it as input and output the same time ?
I wonder because i saw people here doing the same with the sonoff
Maybe i should take a new ESP, Hardwire 2 GPIO and use one explicetly as input, the other as output?
kr0815
#4 Post by kr0815 » 13 Nov 2016, 13:11
Accidently i found out now, if deleting / re-adding the device in Devices section, i get it back to work, so musst be some bug in ESPEasy?
Users browsing this forum: OpenAI GPTBot [bot] and 20 guests
